Old 04-19-2016, 01:00 AM   #1
wise345
Slow I am, boost I must..
wise345's Avatar
Drives: Whiteout 2013 FRS
Grinding noise when shifting into 4th
I noticed it about a week ago, when revving the engine out in third then shifting into fourth I get a grinding noise almost like I don't have the clutch in all the way. I've tried shifting slowly into 4th to see if it's just my shifting but nope, no matter how slow I go I get a grind. Any ideas? Is my transmission about to give in??
It goes into gear just fine but it just grinds once I put it in gear for just a second. Plus it only does it if I'm shifting at 6k+ if I'm just driving calm its smooth as can be.
2013 Rocketbunny V2 FRS
Ag Wheels x Airlift x SBD Turbo x Seibon x Nardi x Spec D x Valenti
wise345 is offline   Reply With Quote
Old 04-19-2016, 03:04 AM   #2
humfrz
Maybe your car's transmission would like some new and different fluid .... ??
That may not help ..... but it won't hurt.....
humfrz
Old 04-19-2016, 08:59 AM   #3
wise345
wise345's Avatar
humfrz
Heard it tricky on these cars, is it too bad?
Old 04-19-2016, 11:16 AM   #4
humfrz
What's tricky ..... ?? ......
Changing the fluid or the 3-4 shift .. ??
To change the fluid, simply loosen the fill plug (to make sure it's not frozen), take off the drain plug, drain old oil, put drain plug back on, tighten, take off fill plug, fill with the proper oil till it won't take anymore, put fill plug back on and tighten down.
There are DIY pictures of where the plugs are on this site.
Some folks like the Motul product.
Keep us posted.
humfrz
Old 04-19-2016, 11:53 AM   #5
wise345
wise345's Avatar
Keep us posted.
humfrz
Guessing I heard wrong lol. I didn't see it being any different to change trans fluid on our cars as on any other but I've heard otherwise lol.
Will do
Grinding noise in neutral WGMGR Issues | Warranty | Recalls / TSB 28 04-12-2018 02:22 AM
clutch grinding noise BoxerBlock88 Engine, Exhaust, Transmission 13 11-14-2015 06:12 AM
Shifting at high RPM - Grinding Magzter Issues | Warranty | Recalls / TSB 16 12-05-2014 01:24 PM
Grinding noise during slalom JM197 Issues | Warranty | Recalls / TSB 9 08-11-2014 10:50 PM
Grinding noise? frs10 Issues | Warranty | Recalls / TSB 7 09-20-2013 10:57 AM
