Old 11-12-2015, 05:36 PM   #1
BoxerBlock88
Drives: 2013 Scion Fr-s
clutch grinding noise
I'm sure by now most of you have heard of the grinding/squealing noise at idle or in gear. I've recently replaced 2 throw out bearings on 2 seperate scion fr-s this past month. Toyota refused to cover this part or any related parts. Not replacing this right away can damage the trans housing, pressure plate, and or shaft.
BoxerBlock88 is offline   Reply With Quote
Old 11-12-2015, 06:03 PM   #2
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
I always wonder if the noise my clutch is making is normal. =/
But I don't know how to diagnose it... anyone can share some tips?.. :X Thanks.
Old 11-12-2015, 06:09 PM   #3
BoxerBlock88
No clutch should make noise like that. on the front driver side of the transmission there is a open vent. stick your finger in there and wipe the inside. on both occasions i found residue and metal shavings.
Old 11-12-2015, 07:53 PM   #4
humfrz
Well, now, a properly working clutch/flywheel/throw out bearing shouldn't make hardly any noise.
Back in the day, if a throw out bearing was going bad it would first whine ..... then squeal then fly apart ........ as it ground through the fingers on the pressure plate.
After that, the pressure plate (being out of balance) would start to come unglued from the flywheel and tear up the clutch disk, which would mess up the flywheel.
If it all happened all at once, it would "blow", sort like a grenade and blast through the bell housing, ripping up the floorboard. If your legs and private parts were in the way ........ too bad.
Now, having said that, relax and enjoy driving your MT car.
I do ....... of course, I've been "fixed" and at my age sex is no longer that important to me .....
humfrz
Old 11-12-2015, 08:38 PM   #5
UMMMM Thanks? You may want to check out the 20 or so existing threads on throw out bearings in the Engine and Transmission or Issues sub forums.
http://www.ft86club.com/forums/forumdisplay.php?f=72
http://www.ft86club.com/forums/forumdisplay.php?f=8
Old 11-13-2015, 07:12 PM   #6
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Wait so it's definitely not normal if I get a small grinding noise when I let go of the clutch? ....(doesnt happen all the time if I'm very slow & careful with the clutch) >___>
Old 11-14-2015, 12:05 AM   #7
humfrz
Correct ....... not normal.
However, the only way to find out what is wrong is to physically inspect the flywheel, clutch disk, pressure plate, throw out bearing and input shaft bearing by taking it apart.
The only time I have ever heard a clutch "grind" is when all the asbestos (back in the day) was worn off and the disk was "running" on rivets.
humfrz
Old 11-14-2015, 01:16 AM   #8
Ultramaroon
not playing cards
Ultramaroon's Avatar
Are you sure you aren't describing a "creak" when you release the clutch pedal. I have the same issue. It's a dry clutch fork pivot. If you can't drop the trans yourself, take it in. Lots of people with this.
I'll replace the pivot and fork when I replace my TO bearing or otherwise get motivated to drop the transmission. #kindalazylately
Old 11-14-2015, 01:36 AM   #9
humfrz
RIIIIIGHT...........
Think about that for a moment.
* find a soft spot on the gravel driveway
* bust one clip getting it off the universal joint of the driveline
* remove the shift linkage ..... remembering which way it went back on
* remove the clutch linkage ..... oops lost that cotter pin in the gravel
* unbolt the tail shaft from the cross member
* start taking out the bolts around the bell housing ....... all of them EXCEPT the top one
* drag a 2 1/2 gal bucket and place it under the transmission ... maybe with a 2x4
* NOW the last bolt on the top ....... a bitch isn't it
* pull the transmission off the spline and hope it lands on the bucket
* dig a trench in the gravel so you can clear the bell housing from the frame
* ahhhh ...... yes, pop the tops on a few brews and call it a day
NOW, @Ultramaroon ........ when are you going to start that project ......
humfrz
Old 11-14-2015, 01:45 AM   #10
Ultramaroon
not playing cards
Tomorrow! Because you punched me right in the pride.
...unless it's raining.
Old 11-14-2015, 01:51 AM   #11
humfrz
......let's see ....... tomorrow ...... in the PNW ........ rain.. ?? .......
humfrz
Old 11-14-2015, 01:59 AM   #12
Ultramaroon
not playing cards
Forecast says 10% chance of transmission drop.
Old 11-14-2015, 03:17 AM   #13
humfrz
The Tcoat method of clutch service:
Hand keys to service guys
Drive loaner to work
Spend day on forum
Drive back and pick up car
Old 11-14-2015, 06:12 AM   #14
axelo
Drives: Whiteout frs
Well...
Its been years with a throwout going slowly going bad... Read every single thread Tcoat recomended and much more. My Dealer tech simply said its a "use and wear" issue last year when i still was under 36k...
I know that my stock throwout is bad, and when i hoon around, " having fun with my car", i do feel the changes on clutch feel and performance.
My conclusion, if it helps anybody here upon reading this.... if you have a 13' frs and are as "lucky" as i am, that got one frs with the doomed to fail throwout... Take care of it while you can before it breaks every thing else like mentioned in this thread before.
Got my $$ savings for trans drop and see exactly how bad the situation is.
But if you hearing the "whine" and stuff, change that shit.
I sent a nice and polite letter to somebody who i assume doesnt give a shit at toyota about the bad production and of this situation on some of this cars, cause not every car is having the situation. But, hell...so many cars with the same shit frustrating...
Thanks!
axelo is offline   Reply With Quote
bearing, clutch, grind, idle, transmission
Clutch noise new to-day Skye Issues | Warranty | Recalls / TSB 16 11-19-2016 11:42 AM
Clicking / tapping sound + fuel pump noise + clutch grinding Mikeez Issues | Warranty | Recalls / TSB 11 04-26-2015 11:19 PM
Clutch grinding when driving? J-Money Issues | Warranty | Recalls / TSB 0 08-12-2014 03:22 PM
Grinding noise during slalom JM197 Issues | Warranty | Recalls / TSB 9 08-11-2014 10:50 PM
Grinding noise? frs10 Issues | Warranty | Recalls / TSB 7 09-20-2013 10:57 AM
