Old 02-07-2016, 08:45 PM   #1
WGMGR
Drives: WRB Limit BRZ 2015
Grinding noise in neutral
What could this be? Sitting in my drive way in no gear itll make a grinding noise but when I push the clutch in itll go away, it also doesn't make the noise when I go as far as I can tell
WGMGR is offline   Reply With Quote
Old 02-07-2016, 08:49 PM   #2
stevesnj
stevesnj's Avatar
That's the throw out bearing, it's normal. If you get a screeching sound get it replaced. Until then turn up the tunes.
My 2016 Build thread
Old 02-07-2016, 10:56 PM   #3
Ultramaroon
not playing cards
Ultramaroon's Avatar
google "neutral rollover."
Old 02-08-2016, 12:14 AM   #4
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
Is it a serious problem? Because i have that noise too.
Is it self fixable or do i need to take it back to toyota?
FR-Sky is offline   Reply With Quote
Old 02-08-2016, 12:24 AM   #5
Ultramaroon
not playing cards
If the transmission doesn't make any noise while driving then there's nothing wrong.
Idle up to about 2K RPM. I bet the noise goes away.
Old 02-08-2016, 12:31 AM   #6
FR-Sky
FR-Sky's Avatar
So far i only hear it when its idling/neutral. What is transmission sounds like?
I have a N1 exhaust...so i cant hear if the noise goes away or not....
I just try with my dad rev about 2000rpm,, the rattle noise still exist!
Old 02-08-2016, 12:43 AM   #7
Ultramaroon
not playing cards
Do you have a lightweight flywheel?
Old 02-08-2016, 12:54 AM   #8
FR-Sky
FR-Sky's Avatar
Everything stock beside drop in k&n air filter and invidia exhaust.
Old 02-08-2016, 01:02 AM   #9
humfrz
Very few mechanical things that go bad ...... fix themselves, including a bad TOB.
I'd suggest you pay a visit to your dealer and ask to listen to another FR-S for a comparison. While you are there, you may consider asking a tech for an opinion.
humfrz
Old 02-08-2016, 01:08 AM   #10
humfrz
Most manual transmissions, when the clutch is NOT engaged, have a shaft(s) that rotate. This is a "transmission" sound, some call it a "rollover" sound.
It kinda sounds like a quiet clothes dryer, running on low speed, when it's empty.
humfrz
Old 02-08-2016, 01:10 AM   #11
FR-Sky
FR-Sky's Avatar
humfrz
I mean as long is normal,,then i am fine with it.
I just did a little bit research right now,,many people say its a high pressure fuel injection, and its normal. so i dont know...
Old 02-08-2016, 01:12 AM   #12
Ultramaroon
not playing cards
It's probably a good idea to have a dealer tech give it a listen. A little neutral rumble is no biggie but who can say when it becomes excessive?
Old 02-08-2016, 01:15 AM   #13
Ultramaroon
not playing cards
We're specifically discussing the sound of the transmission in neutral. this sound will disappear when you push in the clutch. If it doesn't disappear then it's not the transmission.
Old 02-08-2016, 01:24 AM   #14
FR-Sky
FR-Sky's Avatar
sorry...i dont have this problem...
But i do have the rattling noise problem when idling/neutral.
Transmission Noise in Neutral @ Cold Start Jackal84 Issues | Warranty | Recalls / TSB 57 03-01-2021 03:21 PM
clutch grinding noise BoxerBlock88 Engine, Exhaust, Transmission 13 11-14-2015 06:12 AM
Grinding noise during slalom JM197 Issues | Warranty | Recalls / TSB 9 08-11-2014 10:50 PM
Grinding noise? frs10 Issues | Warranty | Recalls / TSB 7 09-20-2013 10:57 AM
MT, neutral 15-10mph slowing, ratcheting noise bcj Engine, Exhaust, Transmission 7 04-18-2013 12:33 AM
