Builder/Driver/Enthusiast
Drives: 2013 FR-S 6MT Turbo Firestorm
Transmission Grinding Noise
I have a grinding noise when the clutch is engaged. It happens N-1-2-3-4 but is is 5-6. I replaced the clutch, release bearing, and tranny fluid. Noise is still there. I took a video and will attach when I have a chance to upload. I though I might be a synchro or another bearing in the transmission but not sure what. Tranny fluid had no metal flakes and looked as clean or cleaner from other posts on here.
Before the comments come in I have searched and haven't seen this issue yet. Car now has exedy stage 1 clutch, fa20 club turbo, and AEM meth injection. Noise started 1 year after turbo on stock clutch.
Andy
1977 Triumph Spitfire 1500 - New Project 2013 Firestorm FR-S 6MT Turbo - Sold 2013 Honda CBR 250 Repsol- Toy 2017 Toyota Tacoma - The Rig Last edited by RedFR-s; 06-27-2016 at 10:49 AM. |
#2 |
Post up the clip and we'll give it a listen.
#3 |
My crystal ball tells me it may be a bad pilot bearing .......
![]() humfrz |
#4 | |
Unless the forces of the clutch are causing it...
Andy
1977 Triumph Spitfire 1500 - New Project 2013 Firestorm FR-S 6MT Turbo - Sold 2013 Honda CBR 250 Repsol- Toy 2017 Toyota Tacoma - The Rig |
#5 |
Updated with video link.
Andy
#6 |
Very loud neutral rollover. What do you hear when it's in gear? Can you have someone take a clip of you rowing through the gears?
@humfrz was teasing because without a clip we need his crystal ball. It was wrong this time. Please elaborate on how it sounds for each gear. Your OP is unclear about that.
#7 | |
I'm a but nervous to drive it. I've sourced a used tranny with 2k km on it to swap it out while I rebuild this one.
Andy
#8 | |
After I turned my crystal ball "right side up" it said this: "When the clutch is disengaged, the transmission’s input shaft and the engine’s crankshaft are rotating at different speeds. The pilot bearing allows for this difference. This is why a faulty pilot bearing makes its most noise when the clutch pedal is completely depressed and the clutch itself is completely disengaged. It’s located in the center of the crankshaft flange or flywheel." OK, back to you @Ultramaroon. humfrz |
#9 | |
Just holler if you want a hand and I can PM you the address.
#10 | |
Andy
#11 | |
humfrz |
#12 |
Gonna be in town anyway so easy. Wife is going to the grandson's graduation but they can only take 4 people. Just planning on chilling with the younger one so I will now introduce him to the wonderful world of car diagnostics.
#13 | |
Oh, so you think you are going to figure it out with that long screwdriver stuck up to your ear ....... ![]() OK, give it to me ..... I'll give it a try. DANG! ...... no matter where I put the tip of the screwdriver on this engine ..... it sounds like it's about to fly apart ..... ![]() @RedFR-s ..... I suggest you sell this POS before it completely comes unglued.... Tcoat jr is done here! humfrz |
#14 | |
Son couldn't even tell you what make it is, has never touched a wrench and at 32 years old has never driven a mile in his life. I am ashamed.
| Grinding noise in neutral | WGMGR | Issues | Warranty | Recalls / TSB | 28 | 04-12-2018 02:22 AM |
| Grinding noise when shifting into 4th | wise345 | Issues | Warranty | Recalls / TSB | 4 | 04-19-2016 11:53 AM |
| clutch grinding noise | BoxerBlock88 | Engine, Exhaust, Transmission | 13 | 11-14-2015 06:12 AM |
| Transmission Grinding Into 6th | Mister | Issues | Warranty | Recalls / TSB | 13 | 11-12-2013 10:06 AM |
| Grinding noise? | frs10 | Issues | Warranty | Recalls / TSB | 7 | 09-20-2013 10:57 AM |
