Old 09-20-2013, 10:04 AM   #1
frs10
Drives: tezla
Grinding noise?
last night while driving, i went to make a normal right hand turn and heard some strange grinding noise and the VSC light started blinking... there doesnt seem to be anything under my car or anything and the car is stock.
has anyone had a similar issue or know what this might be?
frs10 is offline   Reply With Quote
Old 09-20-2013, 10:19 AM   #2
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Did this turn involve any kind of an incline or loss of traction? Most likely you unloaded one of the rear tires and it pissed your stability control system off. The noise you heard was most likely the ABS system.
Old 09-20-2013, 10:20 AM   #3
Muskokan
Drives: white Sport-tech
If you can't recreate it, he's probably right ^
Muskokan is offline   Reply With Quote
Old 09-20-2013, 10:28 AM   #4
FRSFirestorm
Red is Fastest
FRSFirestorm's Avatar
Drives: 13 FRS 6MT Firestorm
agree, spirited turn and invoked the traction/stability control. completely normal.
FRSFirestorm is offline   Reply With Quote
Old 09-20-2013, 10:28 AM   #5
frs10
Drives: tezla
i didnt know the ABS system makes that kind of noise?
no, it was a plain jane right turn on even/level flat asphalt...
thats why i found it so strange?
i was going prob 7mph, it was from a red light...
Old 09-20-2013, 10:44 AM   #6
Muskokan
... 2nd gear grind possibly? Were you shifting?
Old 09-20-2013, 10:47 AM   #7
FRSFirestorm
Red is Fastest
The rear lsd. Mine will groan a bit, sometimes, on slow speed turn.
Old 09-20-2013, 10:57 AM   #8
frs10
Drives: tezla
no shifting, AT
Grinding from 5th to 6th tn08 Issues | Warranty | Recalls / TSB 3 08-08-2013 09:26 PM
6th Gear Grinding KpAtch3s Issues | Warranty | Recalls / TSB 0 06-18-2013 07:07 PM
Spacers grinding...? Yamajee Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 05-09-2013 02:54 AM
Awful grinding!!! DatGoodBRZ Issues | Warranty | Recalls / TSB 13 11-09-2012 04:13 PM
