Old 11-28-2014, 02:46 AM   #1
Magzter
Drives: Toyota FT86 GTS Velocity Orange
Shifting at high RPM - Grinding
Hi all,
I haven't been driving manual for too long but I've been trying to shift at high rpm lately. Particularly in first gear, as soon as it gets past 5-6k revs the second I go to clutch I hear a grinding noise. How am I supposed to shift at high rpm in first?
Magzter is offline   Reply With Quote
Old 11-28-2014, 06:49 AM   #2
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Is this what is happening?
You're at a red light, you engage the clutch and find the point of engagement (No Grinding)
Once the clutch is fully engaged -- You rev the car all the way up to 5K RPM
Now you want to shift into 2nd gear -- You push the clutch in *Grind* (The shifter hasn't moved yet)
Is this correct? Do I describe it perfectly?
N1rve
Old 11-28-2014, 08:14 AM   #3
Magzter
Yes correct, just on a much faster scale. I don't think it's an issue with the car as my brother (long time manual driver) tried it tonight at 7k revs and no grind. I believe its my technique, he says I shouldn't push the clutch in all the way.
Old 11-28-2014, 08:52 AM   #4
Nm86
Drives: Ultramarine
I disagree with not pushing the clutch all the way in. Some people say that, you don't need to push it all the way down just past the engagement point. We'll for me I'm 6'6". It's easier to hammer that thing to the floor and shift. Also having the clutch on the floor will push the clutch further away from the flywheel. I'm guessing you are just trying to grab the gear a little before you actually have the clutch fully engaged.
Nm86 is offline   Reply With Quote
Old 11-28-2014, 09:07 AM   #5
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Bad syncros. Common problem. Take it to the dealer and get a new transmission like the rest of us did.
Old 11-28-2014, 12:22 PM   #6
Kayshart
I get that quite rarely too. Sometimes at just at low speeds, gear fully engaged, and when half clutching. I just quickly clutch back in and try to re-engage the gear.
Never experienced it at high rpms though.
Kayshart is offline   Reply With Quote
Old 11-28-2014, 02:43 PM   #7
strat61caster
strat61caster's Avatar
Is your foot still partially on the gas when you go for the clutch? Not intentionally, just being very quick with your feet in order to stay smooth.
I get a weird noise when I overlap those inputs (gas and clutch) that could be described as grinding, maybe try slowing down your process to see if you can figure out exactly what you're doing as the noise occurs.
It doesn't make sense for a transmission to grind without you moving the stick.
Old 11-28-2014, 03:38 PM   #8
Ultramaroon
not playing cards
Ultramaroon's Avatar
Are you guys describing that brief little "vroom?" I get that all the time and wonder if there are 2 separate throttle curves - one for clutch engaged and another for disengaged.
...or some other high-tech DBW bullshit. Not a hater, just miss my throttle cable. <sniff>
Old 11-28-2014, 03:39 PM   #9
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
[ame="https://www.youtube.com/watch?v=GyJItQYPXQc"]Dogma clip - YouTube[/ame]
The Following User Says Thank You to 7thgear For This Useful Post:
Ultramaroon (11-28-2014)
Old 11-28-2014, 04:12 PM   #10
strat61caster
I guess it could be described as a vroom, just a weird kind of rattly noise. For me it has less to do with drive by wire and more to do with revving while the clutch is being pressed.
I miss my throttle cable too.
Old 11-28-2014, 04:21 PM   #11
stugray
Drives: 2013 GBS BRZ Limited
I dont know if it is just my car or what, BUT - I only have to push the clutch pedal in about 3 inches for each shift. That is fully disengaged.
The ONLY time I ever have to push the clutch to the floor is to start the car.
WHY would a syncro make a noise before pushing the car OUT of gear. The syncros are stationary at that point sandwiched between the engaged-gear & the slider.
If I understand what the OP is saying, he hears the grind when disengaging the clutch before pushing the shift lever.
I get the "rattly noise" sometimes when shifting, but I attribute that to the HPFP, not the tranny.
THAT noise is worse when cold. I actually use the absence of that noise to tell me when the engine is warmed up.
It sounds a little like a heat shield that is loose.
Old 11-28-2014, 06:59 PM   #12
strat61caster
So when you overlap engaging the clutch and the gas pedal you get a rattle noise but only if it's warm? Interesting, mine is regardless of temperature.
Again, every post I've made in this thread is only in regards to overlapping clutch and throttle inputs.
Old 11-29-2014, 12:31 AM   #13
Reaper
Reaper's Avatar
Drives: violent
Don't know how I missed that. Must have been responding to multiple similar transmission threads on mobile.
Old 11-29-2014, 01:06 AM   #14
Koa
I miss the response and character of a throttle cable too man. It's so annoying to blip the throttle on these cars because the computer will hold the blip so artifically- like flutters above 1k rpms for a split second. Just enough to feel "not right".
The Following User Says Thank You to Koa For This Useful Post:
continuecrushing (12-03-2014)
Clutch Vibrates at high RPM Shifting, normal? Error Issues | Warranty | Recalls / TSB 6 08-03-2014 01:25 PM
Grinding in the 5th Hawk77FT Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 06-21-2014 02:10 PM
High RPM Shifting Issue? Rinzler Issues | Warranty | Recalls / TSB 5 05-17-2013 12:30 AM
shifting and down shifting feel Lowellrenzo Scion FR-S / Toyota 86 GT86 General Forum 23 07-08-2012 05:09 PM
