Drives: 2015 FR-S
Grinding noise during slalom
I know this isn't ideally the way you would treat a car, but I've noticed a loud grinding noise once when I was making sharp turning motions, i.e. slalom. The noise sounded like it was near the wheels, perhaps the wheels themselves. I was only going around 30mph.
The car is new, no mods. |
Drives: Subaru BRZ
Sounds like active handling
I'd suggest you check your car's tires pressures.
Most likely it's just the sound made by the tires on the road. humfrz |
Drives: 2014 GB Scoobie BRZ
mine makes strange noises while turning hard, I do believe it's my brakes.
Thanks
TC or LSD?
Drives: car
Traction control noise.
Drives: 2013 6spd Argento FRS/1995 BMW 325i
simple fix, hold traction control button for at least 3 seconds. Problem solved
Drives: 2013 DGM BRZ, 2020 C8 Corvette
that just replaces the grinding noise with a screeching noise.
My DGM BRZ vid: https://www.youtube.com/watch?v=0OL9OhxexAA
My car journal thread: http://www.ft86club.com/forums/showthread.php?t=43402 |
Drives: 2014 SWP BRZ, MT
TC tries to correct for skidding by using ABS to apply braking force. Try as suggested to drive in VSC Sport or TC Off.
#10 |
AutoX-10/10ths every run
Check your lug nuts. If they are loose it'll allow the rotor to shift on the hub and drag on your brakes. This will be especially evident when turning as there is a stronger lateral load on the wheel/tire.
| Grinding in the 5th | Hawk77FT | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 4 | 06-21-2014 02:10 PM |
| Transmission Grinding Into 6th | Mister | Issues | Warranty | Recalls / TSB | 13 | 11-12-2013 10:06 AM |
| Grinding noise? | frs10 | Issues | Warranty | Recalls / TSB | 7 | 09-20-2013 10:57 AM |
| Grinding from 5th to 6th | tn08 | Issues | Warranty | Recalls / TSB | 3 | 08-08-2013 09:26 PM |
