Old 05-29-2020, 01:05 AM   #1
DoubleAKash
Drives: 2019 Subaru BRZ - JDL Turbo Kit
wheels and tire size recommendations
Hi All,
So next up on my build is wheels, tires, and coilovers.
I'm thinking about 18x8.25 or 18x8.5 wheels but mainly leaning towards 18x8.5 or in the case of XXR they only have the chromium black in 18x8.75
I'm not tracking the car but just do some daily spirited driving but I really love the look of the WedsSport TC105X except the price but I've heard are some light wheels. The only other wheel I've found that's similar to that look is the XXR 527s
Does anyone have any recommendations to similar wheels?
Ideally I'd love to have that clean look on a white BRZ and wanted to know whether its worth getting the 527s and what bolts to get and what tire size to get to fit the wheels if I did get them, I'm conflicted between 225 or 235s
DoubleAKash is offline   Reply With Quote
Old 05-29-2020, 05:39 AM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
Imho OE bolts should work fine, unless you plan to use slip-on wheel spacers thicker then 3mm. But if you are buying new wheels, why not buy with right offset initially instead of using spacers?
If not tracking, not worth going for too wide tires, retain some fun instead of tramlining, i'd go for 225.
Old 05-29-2020, 06:54 AM   #3
86MLR
86MLR's Avatar
NA street car
17 x 8 with 215-225/45 "good rubber".
You need sidewall in street cars, every little bit helps for a more compliant ride.
Did I mention "good rubber".
I cannot stress enough about "good rubber".
Old 05-29-2020, 08:25 AM   #4
Ernest72
Originally Posted by 86MLR View Post
NA street car
I agree. Also 17 is usually lighter than 18. Lightness is important for this platform. That’s if comfort and performance are important. I am on 17x7 STI wheels and Michelin PS4s 215 45 and grip is amazing. So much so, I miss my A/S tires that allow some oversteer. They go back on in November.
If looks are more important than get what you think looks good.
Old 05-29-2020, 09:08 AM   #5
Mike_ZN6
Mike_ZN6's Avatar
Drives: 2016 Toyota 86
The most popular sizes for this car are 17x9 and 18x9.5. Most people run 245/40 on 17x9 and they run 245/35 or 255/35 on 18x9.5. Acceptable offset range for these sizes is +35 to +45.
Mike_ZN6 is offline   Reply With Quote
The Following User Says Thank You to Mike_ZN6 For This Useful Post:
Shizuka (05-29-2020)
Old 05-29-2020, 09:22 AM   #6
Vital
Drives: 2015 BRZ
If you want similar looking wheels to XXR 527 and TC105X check out Konigs Dekagram they are flowformed and light weight too. I personally have these and love them. Agree above for a street car i'd get 17x8, 17x9 or 18x8 wheel sizes.
The Following User Says Thank You to Vital For This Useful Post:
DoubleAKash (05-29-2020)
Old 05-29-2020, 09:58 AM   #7
ZDan
ZDan's Avatar
Drives: '23 BRZ
225/40-18s are closer to stock diameter than 235/40-18, which are 0.5" to 0.7" bigger in diameter. I'd say either aim for 225/40-18 on 8" - 9" wheels, or bump up to 245/35-18 on 8.5" - 9.5".
Personally I prefer 17" wheels fwiw...
Old 05-29-2020, 10:15 AM   #8
churchx
churchx's Avatar
Drives: 2014 GT86
I see only one extra gain for 18", and it might be mostly for twin owners in EU. All new top UHP tires like MPS4S, Conti sportcontact6, Goodyear eagle f1 SS are available only beginning with 18" size, limiting a bit tire choice to earlier tire models for those running 17", or getting tires from other classes.
Not an issue for US twin owners, as eg. MPS4S available there in 17" too.
Rare occasions when one upsizes wheel for BBK clearance imho shouldn't count, as it's not clearcut that all 18" will have better clearance as to some 17", and one buying BBK usually does homework, which wheels it clears.
Old 05-29-2020, 02:22 PM   #9
DoubleAKash
I do also plan on supercharging the car within a year as well so I'd like to keep that in mind also....so would the recommendation be to go up to an 18 inch wheel and bigger tire to a 225 size?
Old 05-29-2020, 02:34 PM   #10
DoubleAKash
I wonder if these will have enough clearance with a 17+ with the bremos that come from the factory
The Following User Says Thank You to DoubleAKash For This Useful Post:
Vital (05-29-2020)
Old 05-29-2020, 02:49 PM   #11
Vital
Drives: 2015 BRZ
Yep they do! From what ive seen the 17x9 +40 wheel size does clear factory Brembos. You can check out these threads for examples:
https://www.ft86club.com/forums/showthread.php?t=133660
https://www.ft86club.com/forums/showthread.php?t=134142
Old 05-29-2020, 03:52 PM   #12
ZDan
ZDan's Avatar
Drives: '23 BRZ
Supercharging is no reason to go 18" as tire widths up to 255 are readily available for 17s.
17x9 with 245/40-17 will work fine
The Following 2 Users Say Thank You to ZDan For This Useful Post:
DoubleAKash (05-29-2020), strat61caster (05-29-2020)
Old 05-29-2020, 07:58 PM   #13
86MLR
86MLR's Avatar
I was running 235/40 17 on 8" RPF-1 turbocharged at around 270hp and grip was fine.
The Enkie's fit the OEM Brembo's as well.
Old 05-29-2020, 08:47 PM   #14
Shizuka
Shizuka's Avatar
Drives: 2018 BRZ PP (Modified)
18x9.5 if you want the hotboi concave looks, 17x9 if you're a performance guy. I'd skip the XXRs and get some higher quality wheels, but that's just me. Nothing wrong with them for a ultra budget wheel
Shizuka is offline   Reply With Quote
I want 18x8.5" wheels, please help w/ tire size Lakitu Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-20-2018 04:24 AM
Best tire size for 17x9 wheels Elliotw Tracking / Autocross / HPDE / Drifting 3 09-30-2017 01:22 AM
optimal tire size for stock wheels brillo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 12-05-2015 12:01 PM
Tire size question on 18 x 9.5 all around wheels. 8six_frs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 29 03-24-2015 10:09 PM
Tire size for 18x8 wheels?225/40 or 245/35 FT86RGV Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 06-06-2013 01:24 PM
