Old 03-20-2018, 12:40 AM   #1
Lakitu
Lakitu's Avatar
Drives: 2017 Halo 86
I want 18x8.5" wheels, please help w/ tire size
Okay.. (deep breath)
I am getting 18x8.5" wheels and I want a straight lineup with the fender with a good quality tire, like Pilot Super Sports or Hankook v12.
After 6 hours of research, I still don't get tire size. And I don't get that when you are looking for the tire size that fits your wheels, they ask you what tire size you want for your wheel, which is exactly what I'm trying to find... Dog chases its tail. I punch in the calc and convert 8.5" to mm it comes out to be 215.9mm. I don't get how if this is the maximum fitment for a 8.5" wide wheel, how can there be tires 255 and 300 wide that also fit a 8.5" wide wheel? The rubber would be oozing off the sides of the wheel, wouldn't it?
I just want to find out the perfect tire size to use on 18x8.5 wheels, and the offset for perfect fender alignment (which Tirerack seems to only offer +45 so I might have to buy directly from Enkei). Any help much appreciated.
It's midnight and I feel like I wasted an entire day and learned absolutely nothing. Some day I might get it.
Build Thread / Daily Driver
OFT Stage 2+, GrimmSpeed CAI, JDL Ultra Quiet FP, Perrin 2.5" Resonated CBE, Enkei 18x8.5 +45, 245/35 Continental ExtremeContact
Lakitu is offline   Reply With Quote
Old 03-20-2018, 01:58 AM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
By manufacturers, on 8.5 wide wheel minimum tire width is 225, ideal 235-245, max tire width 255. Quick googling on best tire width for wheel width should turn out several charts/tire calculators suggesting that.
As stretching tire reduces tire sidewall flex, but fitting too wide for rim adds sidewall flex (don't go overboard with either to not cause issues, keep within numbers min-ideal-max above), i'd probably keep on narrower end for more steering sharpness with 225-235.
Old 03-20-2018, 04:24 AM   #3
Boomerang
86
Boomerang's Avatar
I'm running 18 x 8.5 +45. 1" lowered on RSR superdown springs. Camber bolts soon to be camber plates on front and LCA soon on rear.
Camber is sitting on around -1.5 front and -2.1 rear presently however I will be aiming for -2 front and -1 rear for street with new hardware.
Running 225's presently and they are "stretched" a bit but feel good on steering etc. Could probably run 235's without feeling any difference.
TLDR: 225's min, 255's max. 235-245's best as @churchx said
Pics below so you can see my current setup(also coz I love my wheels );
Tire Size Recommendation for RE-71R on 18"x8.5" +42 RAYS 57Xtreme Wheels RJasonKlein Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 12-29-2016 11:12 AM
16" tire size that would = 4.55 FD? RacingCanuk Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 02-11-2016 01:26 PM
Tire size help? XXR 530 18x8.75 +33mm cesar9127 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 02-10-2016 04:13 AM
Tire size for square 18x8.5+38 lowered on coilovers? B$ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 10-07-2015 05:50 PM
Tire size for 18x8 wheels?225/40 or 245/35 FT86RGV Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 06-06-2013 01:24 PM
