Old 09-29-2017, 05:58 PM   #1
Elliotw
Elliotw's Avatar
Drives: '18 BRZ tS, '18 GTI SE, '11 RS
Best tire size for 17x9 wheels
What tire size are people running for mostly track duty light street duty on 17x9 +42 squre wheels on stock suspension? No rubbing please.
235? 245? 255? 265?
Thanks,
Elliot
Elliotw is offline   Reply With Quote
Old 09-29-2017, 08:30 PM   #2
FirstWinter
Drives: Car
I see mostly 245 being run on 17x9. But you can get away with 235 or 255. Some tires run wide/narrow so they work too.
FirstWinter is offline   Reply With Quote
Old 09-29-2017, 09:41 PM   #3
bslate3
Drives: 2015 CWP BRZ
I think 245's for championship and match tours and 255's for Pro Solo's because of the taller gearing.
bslate3 is offline   Reply With Quote
Old 09-30-2017, 01:22 AM   #4
strat61caster
strat61caster's Avatar
245-40-17 is the standard choice, same diameter as stock, I think 255 has been run on stock suspension but it is a bit taller or shorter depending on the profile size.
ineedyourdiddly
Elliotw (10-08-2017)
Good Tire size for 17x9? J-Money Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-05-2016 08:30 AM
The rite tire size? rpf1 17x9 +45 Gillams Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 39 04-22-2015 12:37 PM
Tire size question on 18 x 9.5 all around wheels. 8six_frs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 29 03-24-2015 10:09 PM
Best performance tire size for stock wheels? Tenchi Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 04-30-2014 06:06 PM
Tire size for 18x8 wheels?225/40 or 245/35 FT86RGV Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 06-06-2013 01:24 PM
