Old 03-22-2015, 10:57 PM   #1
8six_frs
8six_frs's Avatar
Drives: Raven FR-S
Tire size question on 18 x 9.5 all around wheels.
Hey guys I have a set of 18 x 9.5 +30 offset all around. I am debating on what tires I should get. I am going to be running BC Racing coil overs with 10k Swift springs. I want to be a functional low, Im just not sure on what tires to get. I was thinking maybe 225/40 Front and 245/40 Rear. Thoughts? Thanks.
8six_frs is offline   Reply With Quote
Old 03-22-2015, 11:29 PM   #2
2016 Camaro SS
2016 Camaro SS's Avatar
Drives: Fast
Way too small on the front.
245/35 is as low as I'd go on 18 X 9.5. 255's give it a meatier fit with no stretch at all.
225's will leave your rim sticking out a half an inch, maybe more.
40 sidewall may be a bit much on 18's, but doable.
2016 Camaro SS is offline   Reply With Quote
Old 03-23-2015, 12:21 AM   #3
8six_frs
8six_frs's Avatar
Drives: Raven FR-S
I wont have any rubbing issues with 255/35? I just don't want to rub, thats my main concern.
Old 03-23-2015, 08:11 AM   #4
2016 Camaro SS
Drives: Fast
Not on coils you won't with that offset. There's people running 265's and that's an extremely meaty tire.
I personally run 245/35 squared on 18X9.5 +38 to keep my speedometer close to what it was stock, but 255's will fit 9.5" width the best. You can check some of the tire fitment calculators on the web just to be sure, but I'm positive you will not have issues.
Old 03-23-2015, 08:59 AM   #5
adamg
Drives: brz
depends how low you want to go, if you want to tuck the wheels and be really low do a 215. if you want to be low but not slammed don't go bigger than 225. if you want low but a little wheel gap go with a 235. if you don't want to go low and want a time attack "racecar" stance 245-255
also don't run staggered tires on non staggered wheels. it just looks weird, really weird
adamg is offline   Reply With Quote
The Following User Says Thank You to adamg For This Useful Post:
swarb (03-23-2015)
Old 03-23-2015, 10:37 AM   #6
jlugo711
Drives: 2014 GT86
18x9.5J +38 is pretty much the "all around" set-up for these cars. Most people in the category run 245/35 Front and 255/35 Rear
jlugo711 is offline   Reply With Quote
Old 03-23-2015, 10:40 AM   #7
8six_frs
8six_frs's Avatar
Drives: Raven FR-S
Thanks for the tip! I kinda like the meatier tire look anyways lol
Old 03-23-2015, 10:41 AM   #8
8six_frs
8six_frs's Avatar
Drives: Raven FR-S
I see what you're saying. I still want to be a functional low. So I think I will go 255/35
Old 03-23-2015, 10:42 AM   #9
8six_frs
8six_frs's Avatar
Drives: Raven FR-S
Is +38 really much of a big difference from +30?
Old 03-23-2015, 10:47 AM   #10
jlugo711
Drives: 2014 GT86
It's about a 0.31 inch difference roughly.
Old 03-23-2015, 10:50 AM   #11
8six_frs
8six_frs's Avatar
Drives: Raven FR-S
Meh I can deal with that. Do you think i'd need any fender modifications with 255/35 all around?
Old 03-23-2015, 11:01 AM   #12
JustBoostin
Drives: Asphalt FR-S 6MT
You'll probably have to roll your fenders. It's super easy though.
JustBoostin is offline   Reply With Quote
The Following User Says Thank You to JustBoostin For This Useful Post:
8six_frs (03-23-2015)
Old 03-23-2015, 11:03 AM   #13
jlugo711
Drives: 2014 GT86
Roll the fronts for sure and maybe the rears for good measure. If you're not looking to run too much camber you might want to give the rear a slight pull also.
The Following User Says Thank You to jlugo711 For This Useful Post:
Old 03-23-2015, 02:32 PM   #14
AlexWood
Drives:
I think 225 front and 245 rear would work. This is about 2-2.5in drop with 18x9.5 +34 with 235/40 tires square Name:  ImageUploadedByTapatalk1427135335.240359.jpg
Size:  312.8 KBName:  ImageUploadedByTapatalk1427135416.938537.jpg
They fit with no fender mods and very little rubbing.
AlexWood is offline   Reply With Quote
coilovers, fitment, lowered, wheels
Tire Brand & Size Question ExxelDistributions Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 10-23-2014 05:03 PM
tire size question Frs32907 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 04-22-2014 12:04 AM
Tire size question..? Yamajee Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 11-18-2013 05:21 PM
Tire Size and Ecutek Tune - Stupid question Pokeguyjai Software Tuning 5 10-04-2013 11:43 AM
QUESTION: Rim & Tire Size at NJ & NY Figo NY / NJ / CT / PA 6 07-17-2013 02:21 PM
