Old 05-18-2013, 08:34 AM   #1
FT86RGV
Tire size for 18x8 wheels?225/40 or 245/35
I'm pretty set on buying some wheels that 18x8(TSW nurburgring or Motegi sp10) but the only problem is I don't which tire size to go with. 235/35 would prob be ideal but tire choice is limited so I see everyone going with 225/40. I've also seen a few people go with 245/35. So does anyone know which would provide greater handling, are there any clearance issues(rubbing) at stock height or dropped, how will it affect the speedo reading.
Any help is greatly appreciated.
FT86RGV is offline   Reply With Quote
Old 05-18-2013, 09:07 AM   #2
white_knight
white_knight's Avatar
Drives: 2013 86 GTS - Pegasus White
Why not just go with 225/40? They are ideal for 8" and pretty close to stock tyre diameter.
white_knight is offline   Reply With Quote
Old 05-18-2013, 09:34 AM   #3
jkonquer
Drives: 2005 Subaru STI
My sti stock 17x8 bbs wheels came with 225 potenzas, however some no name brand 235 tires seems to be narrower than the potenzas. So check the actual tires before you buy them
jkonquer is offline   Reply With Quote
Old 05-18-2013, 04:56 PM   #4
FM Wheels
FM Wheels's Avatar
Drives: a car with nice wheels.
245/35 has a smaller sidewall than 225/40. 225/40 is recommended for an 8" wheel, also the side wall will be flat with the wheel.
FM Wheels is offline   Reply With Quote
Old 05-18-2013, 06:05 PM   #5
Efferalgan
Drives: 2025 BRZ, ex-2012 GT86
Already with good 225/40 rubber you'll feel HUGE difference vs. stock. I am just stunned with the difference after installing 18" OZ Ultraleggeras with Dunlop Sport Maxx ST today. Just 1 word - GRIP!!!
I think 245/35 is definetely too much at least for the front. Did you think about 225 on the front and 245 on the rear axle?
Efferalgan is offline   Reply With Quote
Old 05-18-2013, 06:18 PM   #6
adprokid
adprokid's Avatar
Drives: ZN6 / GDB-G
Go 18x8.5 245/35
or 18x8.0 225/40
adprokid is offline   Reply With Quote
The Following User Says Thank You to adprokid For This Useful Post:
Xiijuwa (10-17-2015)
Old 06-06-2013, 03:29 AM   #7
typericey
WRX to BRZ
typericey's Avatar
What's the offset on those? Any side profile pics?
typericey is offline   Reply With Quote
Old 06-06-2013, 01:24 PM   #8
Efferalgan
+48
The Following User Says Thank You to Efferalgan For This Useful Post:
typericey (06-06-2013)
18x8, tire size
optimal tire size for stock wheels brillo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 12-05-2015 12:01 PM
225/35/18 Tire Size? stoneman155 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 03-29-2013 08:09 PM
Tire Size help! J-Money Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 02-04-2013 12:04 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
