Old 04-16-2019, 09:36 PM   #1
18BrzBlue
Drives: 2018 Blue Brz
Track Setup
2018 BRZ 1" lowered Eibach Pro Kit
17x9 +40 offset Konig Dekagram Advan Neova Ad08r 245/40. There is some front tire poke passed the fender. I have been driving this setup for 2 weeks no rubbbing issues.
According to alignment machine I have -2.5 driver rear -2.2 pass rear.
I had camber bolts installed, and they set the camber to -2 for both front tires. I was told this is a good track camber from some local guys. Also there was no poke anymore. When the mechanic came back there was big gouge along the whole tire and a burning rubber smell. Took almost 1/4" out of my almost brand new tire. The other tire was fine... I will have to replace one.
Long story short I am on the fence about what I should do. I only drive this car is my free time. Currently had 16k on it and is under lease, but I think I plan on buying it. I can live with the front tire poke, but is this an ideal set up for tracking. The front sticks out more then the rear. Should I buy spacers?
Basically my questions are?
What would be the ideal track 17x9 Yokahoma Ad08R square track setup?
This was the picture when they camber it to -2 before taking it for a test drive. We should of checked the clearance to the strut.
18BrzBlue is offline   Reply With Quote
Old 04-17-2019, 09:57 AM   #2
Icecreamtruk
Drives: Track preped NA FRS
With a 17x9 (offset seems +40 from what I found) you wont be able to dial in enough camber for track use with lowering springs. Your rear camber is ok, but front is nowhere near enough. I mean, it will be enough to start, but as you corner harder you will need way more than that (or live with the fact that your tire shoulders will be to the cords and it will still be brand new on the inside basically).
Normally, a real track setup is in the -3 to -4 front camber and -2 to -3 rear camber. The tire poking out in the front is fine, not ideal, but miles better than not having enough camber.
As a bandaid for your problem, I would use 3mm or 5mm spacers on the front to clear the springs and get as much camber as you can on those bolts. As a long term solution, get coilovers that can handle track work and lower control arms for the rear and get a good track alignment.
The Following 4 Users Say Thank You to Icecreamtruk For This Useful Post:
kch (06-12-2019), strat61caster (06-12-2019), treedodger (04-17-2019), Tristor (06-12-2019)
Old 04-17-2019, 03:02 PM   #3
18BrzBlue
Awesome thank you for your reply. I will have to hold off on coils at this time due to budget. I plan on going the spacer route in the meantime.
Would you recommend 3mm or 5mm spacer? Also should I replace the wheel studs with extended ones. Due to losing some thread to tighten up the lug nuts. Or will it be okay to track on the regular oem wheel studs?
Old 04-17-2019, 03:18 PM   #4
Icecreamtruk
3mm or 5mm is fine. Some people are anal about not using more than 3mm on OEM studs. I have to go from what I have seen/used myself, and 5mm was fine for me using r-compound tires for 2 years of tracks, car is 5 years old and I have yet to damage or strip a single stud. You do not need extended studs if you stay at 5mm or lower spacers, it doesnt hurt to have them either, so its up to you at this point.
Old 04-17-2019, 07:25 PM   #5
fminicooper
Drives: FRS Hot Lava
Can you recommend which spacer to use?
fminicooper is offline   Reply With Quote
Old 06-12-2019, 04:37 AM   #6
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Please confirm — 17x9 +40 Dekagrams clear Performance Package Brembos fine?
(Based on my experience, 17x8 +40 don't)
timurrrr is offline   Reply With Quote
Old 06-12-2019, 11:57 AM   #7
maslin
Benz Tech
Drives: 2017 BRZ Premium
Confirm that the picture is real and not photoshopped?
There's a picture of it right there, I'd say it clears.
maslin is offline   Reply With Quote
Old 06-12-2019, 12:17 PM   #8
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Confirm that there’s at least a 3mm gap everywhere between the spokes and the caliper; and that you didn’t need spacers to achieve that.
Old 06-12-2019, 12:23 PM   #9
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
I’d recommend against using spacers if your goal is camber: camber bolts can only get you so much camber; and adding spacers will only make the poke worse. Instead, consider using adjustable camber plates. Many coilovers don’t come with camber plates, so getting them now might be a good investment.
The Following User Says Thank You to timurrrr For This Useful Post:
APEX Race Parts (08-02-2019)
Old 06-12-2019, 12:46 PM   #10
ZionsWrath
Thanks
ZionsWrath's Avatar
If you are stock power might i suggest 17x8 with 225/45 ?
Old 06-12-2019, 12:55 PM   #11
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
It won't clear the Performance Package brakes, at least without spacers
Old 06-12-2019, 04:01 PM   #12
ZionsWrath
Thanks
ZionsWrath's Avatar
Ah that sucks.
ARP studs are easy to install, makes it easy to run whatever spacers you want, and with open ended lugs makes tire changes much easier/faster than stock
The Following User Says Thank You to ZionsWrath For This Useful Post:
Joesurf79 (06-13-2019)
Old 06-13-2019, 10:31 AM   #13
Joesurf79
Joesurf79's Avatar
Drives: 2016 White Pearl BRZ Premium
Ah that sucks.
Truth. AFWIW - the studs on mine from the factory were made of wax apparently. Even being super careful - brushing off threads with a wire brush ocassionally, blowing junk out of the lugs before re-threading, etc - Once they hit like 10 track day cycles (wheels on off, change pads, change tires, etc) they dropped like flies. I had more than a handful die - either stripping, jamming, but only had one that broke off...
Joesurf79 is offline   Reply With Quote
Old 08-01-2019, 07:22 PM   #14
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Any updates on how you solved it?
Any new photos?
Suspension setup for flat track supercharged680 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-06-2019 02:23 PM
Recommendation for track lapping day setup WWFT86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 34 02-03-2017 11:58 AM
My track Setup Magiclow Tracking / Autocross / HPDE / Drifting 32 10-09-2015 05:10 PM
Track pad setup recommendations orthojoe Tracking / Autocross / HPDE / Drifting 15 02-25-2013 07:18 PM
Getting my video setup for the track post_break FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 1 12-20-2012 11:57 PM
