Old 04-04-2019, 10:40 AM   #15
jc7993
Drives: Looking to buy
I finished changing the transmission fluid and for the rear differential as well. Does anybody know if the the transmission and rear differential share the same fluid between each other? Or are they separated entirely and have their own contained fluids?
jc7993 is offline   Reply With Quote
Old 04-04-2019, 10:59 AM   #16
maslin
Benz Tech
Drives: 2017 BRZ Premium
The driveshaft does not carry fluid from the trans to the rear end.
Even cars with rear mounted trans axles generally have 2 separated fluids, AMG GT for example.
maslin is offline   Reply With Quote
The Following User Says Thank You to maslin For This Useful Post:
gkubed (04-04-2019)
Old 04-04-2019, 11:03 AM   #17
jc7993
Thank you! Only reason I asked is because I changed the trans fluid first and then had to reverse the car up a ramp to get access to the rear differential and was afraid that the old fluid would get mixed up to the front trans fluid.
The Following User Says Thank You to jc7993 For This Useful Post:
maslin (04-04-2019)
Old 04-04-2019, 11:48 AM   #18
JoeC
Drives: Subaru BRZ Limited
I am astonished at how politely your question got answered. Glad you got it figured out.
JoeC is offline   Reply With Quote
The Following User Says Thank You to JoeC For This Useful Post:
maslin (04-04-2019)
Old 04-04-2019, 12:14 PM   #19
@Ultramaroon hasn't seen it yet.
Old 04-04-2019, 12:58 PM   #20
BRZBlack (04-10-2019)
Transmission and rear differential drain plugs: Are they magnetic? Seanzky Engine, Exhaust, Transmission 22 07-25-2018 07:55 AM
Magnetic Drain Plugs come stock for Transmission/Differential? razahuss Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 07-03-2018 08:42 AM
Greddy Magnetic Oil Drain Plug or Fumoto Drain Valve? tracerit Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 01-04-2016 07:36 PM
Best magnetic drain plug? FR-Sizzle Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 09-28-2015 01:07 PM
Magnetic oil drain plug, effective? BRZPDX Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 7 02-16-2013 11:59 PM
