Old 09-07-2016, 05:11 PM   #15
FirestormFRS
Remove your hood when you install it to control temps.
FirestormFRS is offline   Reply With Quote
Old 09-07-2016, 06:08 PM   #16
churchx
churchx's Avatar
Drives: 2014 GT86
Better add fan blowing on it
But yes, due mentioned by Mike points of bad thermal properties, not sure slight weight savings are worth probably extraorbitant price and probable cracking issues. They could have at least make it long tube 4-2-1 to make interesting contender with Ace / Nameless with more area under curve.
Old 09-07-2016, 06:22 PM   #17
ryoma
ryoma's Avatar
Originally Posted by celek View Post
Have you seen my build LOL
just checked out your build and I would recommend you look at the ACE header for your build if it wasn't already in your list of options
http://www.ft86club.com/forums/showthread.php?t=80609
Old 09-07-2016, 08:45 PM   #18
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
Depends on the power curve of what @celek is looking for and where he wants to use it.
CounterSpace Garage is offline   Reply With Quote
The Following User Says Thank You to CounterSpace Garage For This Useful Post:
celek (09-09-2016)
Old 09-07-2016, 10:00 PM   #19
Lantana frs
Drives: 13 frs red
Wont be easy to do a shade tree weld repair on these.
Lantana frs is offline   Reply With Quote
Old 09-07-2016, 11:12 PM   #20
Yep, it looks like something I would have made out of flex pipe, back in the 50s .......
(Sorry, manufacturer, I'm jest ah messen wich ya .....)
Old 09-07-2016, 11:16 PM   #21
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Is it really TI or just Ti coated?
Old 09-07-2016, 11:34 PM   #22
AceHeader-MT
AceHeader-MT's Avatar
Drives: 2012 FR-S
We have one
It comes with a high price tag and zero warranty. TI is just too vulnerable to cracking and with the close quarters of the FT chassis it just isn't something we want to push mainstream. Also without bending the design isn't optimal to the types of gains we prefer on our cars.
We do have long term plans for inconel, but we're just not there yet.
Why do we have one you ask? Because why not
AceHeader-MT is offline   Reply With Quote
The Following 10 Users Say Thank You to AceHeader-MT For This Useful Post:
akyp (09-08-2016), celek (09-09-2016), Cop (09-11-2016), Drakiv (09-11-2016), Hostile_Kittens (09-08-2016), Iceman (09-11-2016), new2subaru (09-11-2016), ohmai18 (09-11-2016), Tcoat (09-11-2016), wparsons (09-08-2016)
Old 09-08-2016, 12:19 AM   #23
Tokay444
Extreme heat and vibration is the bane of Ti.
Titanium itself does very well in extreme heat.
It's a great insulator.
Old 09-08-2016, 12:58 AM   #24
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
While Titanium is light and resistant to high temps it does not fatigue well. As @CSG_Mike said, it will crack. Guaranteed. The best materials for headers in order are 304 ss, 321 ss, and 625 inconel. Although the materials are priced accordingly. And because of that 304 ss headers are most common.
321 headers are considerably more expensive but because of the materials fatigue resistance at high temps you can get away with thinner wall tubing and therefore a lighter header. Where .065" is suitable for 304 you can get away with 0.049" wall with 321. And same goes for inconel. Inconel headers can be insanely thin and still resist cracking. Like 0.029" wall thickness! If you ever get the chance to pick up a set of indycar, F1, GTLM, etc. headers they feel like tin foil. It's crazy!
Here is a more informative post on header materials: http://www.enginelabs.com/engine-tec...-race-headers/
kask2_6.0 is offline   Reply With Quote
The Following 8 Users Say Thank You to kask2_6.0 For This Useful Post:
akyp (09-08-2016), Cop (09-11-2016), CSG Mike (09-08-2016), DustinS (09-08-2016), Hostile_Kittens (09-08-2016), Jonsey (09-08-2016), ohmai18 (09-11-2016), wparsons (09-08-2016)
Old 09-09-2016, 09:00 AM   #25
celek
Resident Gear Head
celek's Avatar
I have seen ACE and spoke to them Via PM's on here.
I want max power possible for road track use at high RPM.
trying to finish this engine, By the time I am done I could have bought a 2nd used 86 with the money invested... I need some partners, @AceHeader-MT
13:1 CR
Bored sleeved Stroker 2.3ltrs
Custom rod to stroke ratio
Piper Race cams
Ferrea complete valvetrain
Goal exceed 275 WHP at 9500RPM
celek is offline   Reply With Quote
The Following User Says Thank You to celek For This Useful Post:
Old 09-11-2016, 03:56 PM   #26
CounterSpace Garage
13:1 CR
Piper Race cams
We have a header that may suit your needs on the shelf. Meant for strictly high RPM & Race use.
celek (09-12-2016)
Old 09-11-2016, 04:02 PM   #27
ohmai18
ohmai18's Avatar
Drives: Subaru BRZ
Originally Posted by AceHeader-MT View Post
We have one
You have plans to do a header with inconel...?
Sent from my SAMSUNG-SM-G900A using Tapatalk
ohmai18 is offline   Reply With Quote
Old 09-11-2016, 05:07 PM   #28
spaggiari
Drives: H4WD
There are some examples with titanium application for exhaust systems in f1. Even now.
Not just Inconel.
If you can find a special titanium alloy,there is no problem even with cracks. VT18m as a sample.
Usually it is the back side of exhaust systems,but in case of f1 car,it is still hot enough..Titanium heat conductivity is low,this is why temperature drop is lower and gases speed is higher.
spaggiari is offline   Reply With Quote
WINDOW WONT GO UP! Moe23 Issues | Warranty | Recalls / TSB 26 02-07-2022 02:20 PM
Lugs wont fit ChrisP Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 02-01-2016 01:23 PM
Does anyone manufacture a 3" resonated no-cat front pipe? boomslang Engine, Exhaust, Transmission 2 09-04-2014 08:22 PM
6MT wont shift? StRacngtC06 Issues | Warranty | Recalls / TSB 14 01-07-2014 11:59 AM
Car Wont Start Up HELP !!*** ScionFR-S Issues | Warranty | Recalls / TSB 20 11-28-2013 01:01 AM
