Drives: Raven Scion FR-S
so i went to turn on my car this morning and it completely shut down… lights and electronic things worked like radio and unlocking doors lights horn etc went to turn the key to just where the gauges come on and nothing happened car completely shut down. the car never gets to actually turn on or even catch. i noticed that if i disconnect the red terminal of the battery and let it chill for 5 minutes and put it back on the car will start. i also tested to see if it was the battery: i just let the lights go on and they shortly went off for some reason. i have no idea whats happening to this piece of shit car i want to burn it lol I'm going to have to bring it to the dealer but really hope my warranty isn't voided. all i have is a CAI HIDS, FOGs, Tails, Axle Back and thats it
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
Well, that's got to be aggravating ....
![]() I'd guess either the battery isn't holding the charge or the alternator isn't making electricity (or allowing it to go to the battery). So, a load test on the battery and a charging test on the alternator may be in order. Now, is THAT old school or what .... ?? Maybe somewhere in your electrical mods, a battery drain was created ..?? humfrz |
#3 | |
Sounds like you swapped every major exterior light on the car and now your battery won't hold a charge.
Looks like an open and shut case to me, there's an electrical fault somewhere. You're going to have to go through all the work you did if you did it yourself, check up on the specific kits you bought and see if there's anything wrong (incorrect resistances or something) or if you paid someone go bitch to them to fix their mistakes. |
#5 | |
hmmmm......so, did you have the battery "load tested", not just tested to see if it reads 12 volts?
If you have a multi-meter, you can test to see if you have an open circuit and track it down. Happy hunting ...... ![]() humfrz |
NASA SpecE30 Racer
Lights or aftermarket alarm/auto start would be my guess.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
SLO NO MO
If you've ever let the battery discharge to the point where it doesn't have enough juice left to crank the starter, I bet the battery's not holding enough charge to start.
My stock battery exhibited the same type of behavior, and since I keep a dash cam on while parked, I figured it was time to swap it out with something better suited for all the additional electronics I've added as well as needing to keep power going while parked (until voltage drops to 12V, which should just be enough to start the car). Ended up going with an Optima Yellow Top D35. |
#9 | |
#10 | |
SLO NO MO
Sent from my Nexus 7 using Tapatalk 4 |
#11 |
Do I need to look for certain specs when getting the battery
#12 |
Well, ScionFR-S, are you sure it's the battery? Did you have it load tested?
If the battery isn't bad and you replace it and not fix what is wrong, it will just drain the new battery (no matter how big it is) .... it will just take longer.... ![]() humfrz |
#13 |
Thupercharged
Also of note, disconnecting the battery is not a good idea with modern cars. For the sake of your entire electrical system, try not to run the car without a battery connected to the charge/start system
2013 FRS
Vortech V3 11psi Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300 2019 Series.Grey STI - Stage1+ SF |
#14 |
SLO NO MO
A group 35 with the proper terminal orientation should fit.
Like humfrz suggested though, get your stock battery tested first. Sent from my Nexus 5 using Tapatalk |
| Car wont start? Anyone else? | ScionFrsFan | Issues | Warranty | Recalls / TSB | 150 | 06-09-2017 09:35 PM |
| Damn odor wont go away | Yruyur | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 29 | 05-05-2015 10:41 PM |
| URGENT : CAR WONT START | DarkCard | Engine, Exhaust, Transmission | 9 | 08-01-2013 08:57 PM |
| Front bumper wont come off! help! | mashal | Cosmetic Modification (Interior/Exterior/Lighting) | 14 | 12-17-2012 02:50 PM |
| Push Start Rough Engine Start Up | joergasm | Engine, Exhaust, Transmission | 3 | 12-12-2012 03:44 AM |
