Old 01-30-2016, 10:16 PM   #1
ChrisP
Lugs wont fit
I just got my Avid-1 AV20 wheels and noticed that when I tried to put them on with the stock lug nuts i couldnt get a socket over it because it runs into the wheel. Do you guys know of lugs that are smaller in diameter so I can get a socket over them?
ChrisP is offline   Reply With Quote
Old 01-31-2016, 04:21 AM   #2
Redstar
Destroyer of Tires
Redstar's Avatar
Drives: 2001 Honda Accord, 1997 Lexus ES300
A lot of aftermarket wheels don't use stock lug nuts. Plenty of brands out there that make lug nuts though. Check the vendor classifieds here.
Redstar is offline   Reply With Quote
Old 01-31-2016, 06:27 PM   #3
headlikeahole
headlikeahole's Avatar
Drives: Ultramarine toyobaru
Aftermarket lugs usually come with socket that will fit into nearly any rim
headlikeahole is offline   Reply With Quote
Old 01-31-2016, 08:38 PM   #4
tyler_win_photo
tyler_win_photo's Avatar
Here are some options...
You can either use a thinner walled socket. I found Harbor Freight's deep well socket to be very thin walled.
Switch to extended lugs so that the lug will protrude out of the lug hole.
Some brands make 17mm lug nuts. One off the top of my head is muteki
tyler_win_photo is offline   Reply With Quote
Old 02-01-2016, 02:23 PM   #5
8R6
8R6's Avatar
Drives: FRS
you need "tuner" style lug nuts which have the smaller outer diameter.
8R6 is offline   Reply With Quote
The Following User Says Thank You to 8R6 For This Useful Post:
ChrisP (02-02-2016)
WINDOW WONT GO UP! Moe23 Issues | Warranty | Recalls / TSB 26 02-07-2022 03:20 PM
Car wont start? Anyone else? ScionFrsFan Issues | Warranty | Recalls / TSB 150 06-09-2017 10:35 PM
Car Wont Start Up HELP !!*** ScionFR-S Issues | Warranty | Recalls / TSB 20 11-28-2013 02:01 AM
SoCal Selling MUTEKI Lugs and Locking Lugs evilconcarne999 Wheels and Tires 0 03-18-2013 03:11 AM
