Old 11-23-2015, 08:42 AM   #1
Moe23
Drives: 2014 Scion FRS MT
WINDOW WONT GO UP!
So today as i was on my way to college, i noticed that my passenger side window wouldn't roll down due to freezing temperatures (live in canada) after i managed to get the window unfrozen, i realized i can only roll the window down not up. any suggestions? also the driver side switch for the passenger window doesn't work. doesn't allow me to roll the window up or down, but the passenger side switch can only roll it down. Any suggestions?
Moe23 is offline   Reply With Quote
Old 11-23-2015, 08:45 AM   #2
MuseChaser
Feeling like thinking....
MuseChaser's Avatar
There's a TSB on the windows for freezing. Contact a dealership. Are you still w/in the warranty period? If so, the fix is on them.
Barry
MuseChaser is offline   Reply With Quote
Old 11-23-2015, 08:49 AM   #3
Moe23
Barry
warranty ended 4k ago
Thanks for the help!
Old 11-23-2015, 08:53 AM   #4
Old 11-23-2015, 08:59 AM   #5
One possibility is you have something "off the track" now inside the door. I haven't looked at the schematics for the mechanism but did have this happen with a GM vehicle once. Every time it rained the window would roll down, but not up. There was a small leak in one of the window gaskets, and it would make one of the plastic pulleys used for "up" slippery enough it couldn't turn the cable. You could roll it up about a half inch at the time by waiting a few seconds between attempts.
Could be worse. A buddy of mine just had to take his Challenger in for warranty work because the window wouldn't stop going up/down the 1 inch for the door open/close (similar to the 86). It completely drained his battery before he could get it serviced. I asked why he didn't just pull the fuse and he gave me that "well duh!" look because he didn't think of it.
Old 11-23-2015, 09:02 AM   #6
wheelhaus
wheelhaus's Avatar
Cold temps won't prevent the windows from functioning, unless water freezes and causes ta jam. This is mostly happens when you just open a frozen door because the window will auto down/up a half inch. Also, I've read some people tearing their weatherstripping when water freezes to the back edge of the glass. If you clean/treat the rubber it should help prevent this. The instructions Tcoat posted above will help reset the motor/sensor.
One freezing workaround is to use a can of de-ice spray, I'm using one from Prestone. It evaporates quickly and won't harm anything. Before you open the door, spray some along the weatherstrip behind the glass, and along the wiper seal where the glass goes into the door. Wait a few seconds and the ice should just fall apart. I carry a backpack to and from work, so in the winter I just keep a can in the bag. If that's inconvenient, Throw a can in your trunk.
wheelhaus is offline   Reply With Quote
Old 11-23-2015, 09:25 AM   #7
Moe23
WORKED!!
you might of just saved my life, thanks a lot buddy!
Old 11-23-2015, 09:26 AM   #8
I would still take it is and try to get the TSBs done. Since it is a cold weather issue there is no way you would have known until now so a good dealer should do them anyway. Worth a shot since I had them done and it worked well.
http://www.ft86club.com/forums/attac...1&d=1389643313
http://www.ft86club.com/forums/attac...1&d=1409711423
Old 11-23-2015, 09:43 AM   #9
Moe23
well now that the window is working, you still think i should take it in?
Old 11-23-2015, 09:45 AM   #10
I would. It will just keep happening and eventually the cut off may not catch things in time and you will actually end up with a damaged window mech.
Old 11-23-2015, 09:51 AM   #11
MuseChaser
MuseChaser's Avatar
Yes, yes, yes. They're aware of the TSB. I haven't had any problems yet that I've noticed, but I mentioned the known issue to the local dealership when I was there having something else fixed. The service manager had the TSB right there on a pile on his desk. He did say that it wasn't a recall, so technically they didn't need to do the work unless the customer had experienced the problem, but since it's already starting to freeze here he mentioned that it's entirely possible that I'd already had trouble but hadn't realized it. He ordered the parts and will schedule me for the repair when they come it, at no charge.
Sooo.. yes. Give it a shot. Hopefully, your guys are as helpful as mine have been so far.
Oh.. and it was Tcoat who brought this to my attention when I questioned the auto-rolldown/up window-cracking for cabin pressure relief design some days ago. Thanks again, T!
Barry
Old 11-23-2015, 10:10 AM   #12
Barry
I am on a window TSB Crusade!
Old 11-23-2015, 10:55 AM   #13
BlueSky
BlueSky's Avatar
Drives: 2015 Aozora BRZ
WORKED!!
@Tcoat saves the day again !
BlueSky is offline   Reply With Quote
Old 11-23-2015, 10:58 AM   #14
Window Shatter / Fracture - passenger small triangular window btune Issues | Warranty | Recalls / TSB 5 12-25-2016 02:14 PM
Window Visor and Frozen Window TSB tinma Cosmetic Modification (Interior/Exterior/Lighting) 9 05-19-2015 01:51 AM
Window Visors and Frozen Window TSB tinma CANADA 0 06-17-2014 02:07 PM
Window Scratched by Window Motor / Lifter? tomkozski Issues | Warranty | Recalls / TSB 22 05-31-2014 07:25 AM
squeaky window due to window rubbing against rubber at the top tracerit Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 5 08-10-2013 05:34 AM
