Old 09-07-2016, 02:13 PM   #1
celek
Resident Gear Head
celek's Avatar
New Ti header the manufacture wont tell me anything
Someone is testing the new Blox Racing Ti setup. Here is the one and only pic I have I got off FB.
When I inquired I was basically shut down.
we'll provide more information on our ti headers when we're ready. the first article was test-fit and is scheduled for testing.. along with some of our other ti products. thanks
celek is offline   Reply With Quote
Old 09-07-2016, 02:20 PM   #2
CSG Mike
CSG Mike's Avatar
Extreme heat and vibration is the bane of Ti.
Old 09-07-2016, 02:21 PM   #3
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
This isn't abnormal. They aren't ready to share more details likely because it's too early for them to confirm certain things about the header in case it changes. They want to share the weight (4.85lbs), materials (titanium), design choice (4-1), and nothing more.
A lot of companies will drum up interest to see what the consumers think of what they've done and any demanded tweaks, as well as to ensure there's a decent buyer base when they launch.
JazzleSAURUS is offline   Reply With Quote
Old 09-07-2016, 03:02 PM   #4
So, celek, what's your beef/question ......
Old 09-07-2016, 03:12 PM   #5
celek
Resident Gear Head
celek's Avatar
Although I have used Blox in previous cars I was inquiring to find out results. They do not have any yet. As my build is nearing final button up of the engine I may be running through a gambit of header combinations..
Old 09-07-2016, 03:38 PM   #6
Amputechture
Drives: 2014 BRZ
Still very much in the development stages I would imagine.
Amputechture is offline   Reply With Quote
Old 09-07-2016, 03:48 PM   #7
kuczynskika
kuczynskika's Avatar
Drives: Harrop TVS86 STi BRZ tS
Aside from weight savings is titanium really worth it at all compared to an all stainless steel exhaust? I'm debating this currently for my own setup.
kuczynskika is offline   Reply With Quote
Old 09-07-2016, 03:57 PM   #8
ryoma
ryoma's Avatar
a full titanium header will probably cost 5x the normal header price lol. you might shave off some extra pounds, but 10 lbs or so is not worth spending that much money on it
Old 09-07-2016, 04:02 PM   #9
CSG Mike
CSG Mike's Avatar
Unless you need extreme weight reduction, no. You'll be constantly replacing headers when they crack.
Old 09-07-2016, 04:03 PM   #10
kuczynskika
Yikes... cracked headers...
Old 09-07-2016, 04:14 PM   #11
celek
Resident Gear Head
celek's Avatar
Have you seen my build LOL
Old 09-07-2016, 04:15 PM   #12
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
back in the day when everyone wanted fancy headers, inconel was preferred.
Old 09-07-2016, 04:22 PM   #13
Shady195
Drives: '13 10 Series FRS #1203
I honestly can't imagine any real need for this, even from a weight savings standpoint.
This is 100% "Check out the mirror under my bumper so you can see my cool header" kind of thing
Tons of penis points with the bro crowd for sure though.
I also have a feeling its not going to sound all that great either; and based on that picture the design is pretty much a copy of any affordable setup you can currently buy.
Shady195 is offline   Reply With Quote
Old 09-07-2016, 04:27 PM   #14
celek
Resident Gear Head
celek's Avatar
Penis points... I need every inch I can get
WINDOW WONT GO UP! Moe23 Issues | Warranty | Recalls / TSB 26 02-07-2022 02:20 PM
Lugs wont fit ChrisP Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 02-01-2016 01:23 PM
Does anyone manufacture a 3" resonated no-cat front pipe? boomslang Engine, Exhaust, Transmission 2 09-04-2014 08:22 PM
6MT wont shift? StRacngtC06 Issues | Warranty | Recalls / TSB 14 01-07-2014 11:59 AM
Car Wont Start Up HELP !!*** ScionFR-S Issues | Warranty | Recalls / TSB 20 11-28-2013 01:01 AM
