Old 06-16-2016, 10:37 AM   #15
lizbrayan
Drives: '15 Scion Frs Steel
Literally the most confused ive been in a long time man
Sent from my SGH-T999N using Tapatalk
lizbrayan is offline   Reply With Quote
Old 06-16-2016, 10:39 AM   #16
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Really unsure how to say, "do not drive until it has been checked out" in a different way.
Let alone going WOT....
The Following 2 Users Say Thank You to Summerwolf For This Useful Post:
Cole (06-16-2016), lizbrayan (06-16-2016)
Old 06-16-2016, 10:40 AM   #17
lizbrayan
Ok so you are being serious, good. Gonna take the car to my mechanic later today
Old 06-16-2016, 10:49 AM   #18
KendallH
Drives: 2013 FR-S Base, 1997 Jeep Wrangler
Your car is fine. If there was an issue you would be showing a check engine light. Don't feed the trolls.
KendallH is offline   Reply With Quote
The Following 3 Users Say Thank You to KendallH For This Useful Post:
choiboie (06-20-2016), lizbrayan (06-16-2016)
Old 06-16-2016, 10:50 AM   #19
lizbrayan
Only cel i get is for not having a cat in my headers but thats it, thanks man
Old 06-16-2016, 10:57 AM   #20
Summerwolf
Panda Trueno
Summerwolf's Avatar
ACTUALLY. Here is the deal. Your car probably is running a little leaner than preferred. You have changed how the air enters and exits the engine without compensating for that. You probably shouldn't go WOT much until you tune for the changes you have made.
The backfiring is unburnt exhaust igniting in the exhaust pipe. When you're on decel the fuel is basically being dumped which is what causes that. When you had multiple cats any unburnt fuel was being burned off before you could hear most of that process.
I probably would wind up getting it checked though since you said you were unsure about your air filter installation.
Old 06-16-2016, 10:57 AM   #21
Summerwolf
Panda Trueno
Summerwolf's Avatar
That is also misleading, there can be issues with a car without showing a CEL.
Old 06-16-2016, 11:54 AM   #22
KendallH
Probably? You're contradicting what you're saying. Initially, you claim that his car is running more lean but then you're saying the pop sounds are from excessive unburnt fuel. I had popping noises and crackles from my exhaust with just a catback. The fact of the matter is, modern OBD2 compliant fuel injection strategy is monitored very closely, and almost any small issue will turn on the CEL.
Old 06-16-2016, 12:03 PM   #23
Summerwolf
Panda Trueno
Summerwolf's Avatar
I am not contradicting what I'm saying. There will always be unburnt fuel in exhaust. When you get rid of the cats and restrictions that unburnt fuel igniting in the pipes than becomes audible as pops (backfires) and burbles.
The 02's seeing no cat is what triggers the CEL here. In larger terms there can be motor damage with no CEL. That isn't the case here....
Old 06-17-2016, 01:14 PM   #24
renfield90
The Stig's German cousin
Unburnt fuel is due to a rich condition, not a lean condition.
A completely lean combustion chamber has no fuel in it.
Not only are you a bad troll, you don't know jack about tuning. Go lurk more and let other people actually provide useful help to those who need it.
The Following User Says Thank You to renfield90 For This Useful Post:
Wayno (06-17-2016)
Old 06-17-2016, 09:16 PM   #25
KendallH
Not even tuning, dude has no idea how fuel injection works.
The Following User Says Thank You to KendallH For This Useful Post:
lizbrayan (06-17-2016)
Old 06-18-2016, 03:58 PM   #26
jwvand02
Drives: 2013 SWP BRZ Limited
Yeah I can't tell if this dude is really just a dipshit or what
jwvand02 is offline   Reply With Quote
Old 06-18-2016, 08:07 PM   #27
turtlefeeder
turtlefeeder's Avatar
Drives: UltraMFrS
no tune yet? probably the problem. threw a new intake in? now engine has more air than ecu can know what to do so it threw more gas in there = ¿?
turtlefeeder is offline   Reply With Quote
Old 06-18-2016, 08:13 PM   #28
lizbrayan
No intake just a drop in filter
Running lean at high RPM BigBrainedMonkey Engine, Exhaust, Transmission 5 08-30-2022 04:45 PM
Running a bit lean on WOT pull Phantobe Software Tuning 16 06-26-2015 01:41 PM
Installed Cusco Catch can wrong? Running lean goshem Engine, Exhaust, Transmission 17 08-19-2014 03:06 PM
running lean EZWood Engine, Exhaust, Transmission 26 10-18-2013 12:53 PM
Slip+CEL = Bank1 running lean? Trashed675 Issues | Warranty | Recalls / TSB 11 03-28-2013 10:53 PM
