Old 07-29-2013, 08:05 PM   #1
EZWood
BAMF
EZWood's Avatar
running lean
I'm running a catless header and I've been throwing a code p2096, post catalyst fuel trim system too lean bank 1. Any idea of risks for this? I know if its too lean I can blow my motor so I don't want any smart ass answers. I'm looking for actual technical discussion as to what is actually too lean and I will provide logs of Afr commanded and measured with corresponding rpm. Is there anything else I should be logging like load or anything else?
Old 07-29-2013, 08:17 PM   #2
Hardrock4445
Hardrock4445's Avatar
Did you run any sort of oxygen sensor spacer? I ran into this code too. So I took the spacer out and got po420 code. Long story short: watch your fuel trims. As long as you are +/- 5% from 0 you are fine. However CEL will affect you traction control systems. So spending time with spacers and washers to get the perfect spot in between where you will get lean code from being too far out, or p0420 code from being too close I've got over 7k on my Catless header with no ill effects and fuel trims +\- 5%
Mods: Perrin CAI, JDL EL header, DC sports Catless front pipe, top speed auto pro-1 cat-back, H&R sport line springs, Headlight blackout, "Demon eyes"
Hardrock4445 is offline   Reply With Quote
Old 07-29-2013, 08:28 PM   #3
EZWood
BAMF
EZWood's Avatar
I have this weird 90% thing on my downstream sensor that was given to me when I bought the exhaust.
Old 07-29-2013, 09:06 PM   #4
mrk1
Drives: Sterling BRZ Ltd
Basic question, is the car tuned for no cats?
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 07-29-2013, 09:08 PM   #5
EZWood
BAMF
EZWood's Avatar
No tune.
Old 07-29-2013, 09:27 PM   #6
arghx7
Drives: car
ECU is not getting an expected rear o2 sensor reading because of the catless header.
The rear o2 sensor is used for the catalyst monitor (which most people are aware of) but it's also used to adjust the reading of the front o2 sensor in cruise operation. It accounts for degradation in the front o2 sensor.
arghx7 is offline   Reply With Quote
Old 07-29-2013, 10:01 PM   #7
EZWood
BAMF
EZWood's Avatar
Which sensor is bank 1 and which is bank 2? If bank 1 is the downstream that explains everything, if bank 1 is the sensor before the cat I'll have some questions. The obvious answer is to have the car tuned, but I have other things that thousand dollars needs to go to, on the other hand if it is running too lean it might be worth it to do a tune first.
Old 07-29-2013, 10:37 PM   #8
mad_sb
Drives: 2013 Asphalt FR-S
We only have bank 1. Sensor 1 is up stream aka primary O2 aka front sensor aka pre cat. Sensor 2 is downstream aka secondary O2 aka rear sensor aka post cat.
The lean code probably indicates sensor 2 is a bit too far from the stream of exhaust gas or has too small of an opening.
Old 07-30-2013, 12:29 PM   #9
EZWood
BAMF
EZWood's Avatar
It was too far. I removed the spacer, probably gonna get a running rich code. Thanks for the help.
Old 07-31-2013, 08:32 AM   #10
mad_sb
or cat inefficiency code P0420. Vibrant sells one you can tweak, it has 3 different orifice inserts IIRC.
Old 07-31-2013, 02:26 PM   #11
HRTROB
HRTROB's Avatar
Drives: Toyota 86
How long were you running the spacer before the code first came up? I've been running an angled o2 sensor on my Borla UEL header for 2,000km now. 2 track days and a lot of highway running with the cruise control on, no CEL so far.
HRTROB is offline   Reply With Quote
Old 07-31-2013, 02:44 PM   #12
EZWood
BAMF
EZWood's Avatar
It comes on pretty quick. Could you post a pic of how yours is mounted please?
Old 07-31-2013, 03:09 PM   #13
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Here you go
Old 07-31-2013, 05:21 PM   #14
EZWood
BAMF
EZWood's Avatar
Here you go
That helps, but do you have a close up so I can determine the angle in relation to the exhaust flow?
RPM dip with A/C running BunnyRZed Issues | Warranty | Recalls / TSB 31 10-22-2014 09:56 PM
FA20 Fuel lean at high boost fix cf6mech Forced Induction 15 05-20-2013 03:33 PM
Running low on gas Arctek83 Scion FR-S / Toyota 86 GT86 General Forum 63 04-15-2013 07:35 PM
Slip+CEL = Bank1 running lean? Trashed675 Issues | Warranty | Recalls / TSB 11 03-28-2013 10:53 PM
Running 19's SocalBurt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 09-04-2012 02:45 PM
