Drives: '15 Scion Frs Steel
Running lean ? Maybe ?
So I got revwork headers put in, still waiting to buy a oft for the tune and take advantage of everything. For the last week or so Ive been hearing burbling and pops from my echaust. Usally in 2nd or 3rd gear. Have a cat back put on with stock front pipe. Today I put in a K & N filter. Not sure if i put it in right gonna go to my mechanic to double check but now the pops and burbles are louder and are almost on command in 2nd or 3rd. I know backfire is a sign of running lean. Can anyone help me? I dont wanna blow my engine.
Sent from my SGH-T999N using Tapatalk |
Huge E85 fan!
Drives: 2016 Scion FRS
Get Torque Pro from the app store and a bluetooth OBD2 port reader. Then tell us what your AFR is at WOT.
When you tune, you NEED to monitor AFR |
Not a troll
If your engine is making those noises, it's already on its way out. I'd suggest you get your mechanic to tear down the engine and see if it's salvageable at this point.
Panda Trueno
Drives: No twin now.
Oh yeah, your motor is really beyond help if its popping and burbling.
Should have got a tune first, remember it is all in the tune how long your motor lasts when you start modifying. |
Not sure if the last two comments are serious or sarcasm...
Panda Trueno
SUPER SERIAL, DO NOT DRIVE UNTIL IT HAS BEEN CHECKED OUT!!! You'll just regret it if you cause more damage, but the damage may have already been done
![]() Don't wind up an internet meme lizbrayan. |
Its only been a few weeks with headers and less then a day with the air filter, care to explain whats going on and making the car run lean?
Panda Trueno
Obviously the 02 sensors are not reading correctly and neither is the MAF. You have changed all the air coming in and exiting the motor. It isn't responding correctly. Plus the K&N oil just coats the MAF sensor and usually breaks it! You said you may have not installed the air filter correctly either!?!?! Poor car.
Went for a quick drive at wot at around 5k-6k the lowest afr i got was 11.84 and at idle it was at a 14.7
#10 |
Panda Trueno
You are going WOT in this car!?!? JFC.... Its a goner for sure. Make sure to listen for knocking noises, and loud chirping sounds from your engine bay.
#11 |
I really cant tell if your messing with me or what...
#12 |
Panda Trueno
How can you not tell obvious context through type???!!!! Its in black and white.
#13 |
Idk man guess im not good at context clues but id really appreciate it if youd tell me if youre serious or not lol
#14 |
Panda Trueno
| Running lean at high RPM | BigBrainedMonkey | Engine, Exhaust, Transmission | 5 | 08-30-2022 04:45 PM |
| Running a bit lean on WOT pull | Phantobe | Software Tuning | 16 | 06-26-2015 01:41 PM |
| Installed Cusco Catch can wrong? Running lean | goshem | Engine, Exhaust, Transmission | 17 | 08-19-2014 03:06 PM |
| running lean | EZWood | Engine, Exhaust, Transmission | 26 | 10-18-2013 12:53 PM |
| Slip+CEL = Bank1 running lean? | Trashed675 | Issues | Warranty | Recalls / TSB | 11 | 03-28-2013 10:53 PM |
