Old 08-11-2014, 05:24 PM   #1
goshem
goshem's Avatar
Drives: 16' WRX
Installed Cusco Catch can wrong? Running lean
Hey guys,
I think I migh of installed my cusco catch can wrong because it threw a CEL. I took it to the dealership and they told me the car was running lean because of the catch can, I'm thinking I installed the can wrong?
could anyone help me fix this?
Thank You
goshem is offline   Reply With Quote
Old 08-11-2014, 06:07 PM   #2
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
since you didn't provide any photos or additional info to go on, if you remove it and return it back to stock, and you don't throw a CEL, then you probably installed it wrong.
shiumai is offline   Reply With Quote
Old 08-11-2014, 06:36 PM   #3
goshem
goshem's Avatar
Drives: 16' WRX
here's some photos, since I used the OEM tubing to make the Cusco tube fit into the pcv inlet, I can't use the OEM hoses anymore
http://imgur.com/La4ShDp
http://imgur.com/EUVNOVz
http://imgur.com/W7Xynf1
Old 08-11-2014, 08:35 PM   #4
Turdinator
Señor Member
Turdinator's Avatar
How did you use the OEM hose to fit the cusco tube fit? If you put the cusco hose over the stock hose which is over the pcv valve outlet then i would guess you are getting a vacuum leak there.
1974 TA22 Celica
2013 86 GT
Old 08-11-2014, 09:01 PM   #5
goshem
goshem's Avatar
Drives: 16' WRX
Well I used the little v-clamp clips over the cusco hose to tighten it up with the OEM ones in it and made sure it's a tight fit. Not sure if you can understand what I'm saying. If I'm having a vacuum leak will the CEL come on again? The dealership deleted my CEL so so far there's no CEL.
Old 08-11-2014, 09:16 PM   #6
ML
ML's Avatar
Drives: 13 White MT FR-S
definitely a vacuum leak. The same thing happened to me after a tiny split in the hose appeared
Old 08-11-2014, 09:49 PM   #7
Turdinator
Señor Member
Turdinator's Avatar
Is it set up like the attached drawing? (yes i know i have mad paint skillz)
If you have a vacuum leak and it is running lean it would throw a CEL.
1974 TA22 Celica
2013 86 GT
Old 08-11-2014, 09:58 PM   #8
goshem
goshem's Avatar
Drives: 16' WRX
yup that's exactly how I set it up, good job on the mockup lol. Now it's not throwing the CEL, I actually tightened up the v-clamp more.
Old 08-11-2014, 11:37 PM   #9
goshem
goshem's Avatar
Drives: 16' WRX
Can anyone link me the adapter that I can buy to fit the Cusco hose properly to the pcv outlet
Old 08-12-2014, 10:07 AM   #10
Efferalgan
Drives: 2025 BRZ, ex-2012 GT86
I can:
http://www.ft86speedfactory.com/cusc...-tank-731.html
The pic and the name is wrong but the part # and price is right. I bought&installed it and it works well.
Efferalgan is offline   Reply With Quote
Old 08-12-2014, 10:29 AM   #11
wbradley
Sarcastic SOB
wbradley's Avatar
As per a Subaru tech on another thread I just copied his method.
Bought some 3/8" fuel line tubing (2' for $6), cut a 1" piece and fit it into the Cusco tubing. Slid it on the PCV and done.
Old 08-12-2014, 11:51 AM   #12
goshem
goshem's Avatar
Drives: 16' WRX
thanks guys! appreciate the help
Old 08-13-2014, 01:00 PM   #13
goshem
goshem's Avatar
Drives: 16' WRX
alright, so I tightened all the hose clamps up and I found the culprit.
anyone know how to fix this? I'm pretty sure it's between the bolts that's leaking, I hear a whizzing sound there and when I close it with my fingers it goes away.
Old 08-13-2014, 01:13 PM   #14
wbradley
Sarcastic SOB
wbradley's Avatar
Teflon plumbing tape applied on the threads, then screw the fitting back in place. Make sure the tightening nut is tight.
Catch cans: what are you running? Apex Chase Engine, Exhaust, Transmission 144 08-14-2014 07:17 AM
Is my Cusco catch can correctly installed? wbradley Engine, Exhaust, Transmission 9 02-24-2014 09:49 PM
running lean EZWood Engine, Exhaust, Transmission 26 10-18-2013 12:53 PM
Slip+CEL = Bank1 running lean? Trashed675 Issues | Warranty | Recalls / TSB 11 03-28-2013 10:53 PM
Dealership Installed Wrong Spoiler Snowblind Scion FR-S / Toyota 86 GT86 General Forum 57 02-15-2013 05:57 PM
