Old 06-24-2015, 08:09 PM   #1
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
Running a bit lean on WOT pull
Anyone have any ideas why I'm running a bit lean on WOT pulls? I always seem to be running ~.50 or sometimes more leaner than the command AFR on a WOT pull everything else looks good as far as fuel trims. I know I'm getting a little bit of knock but that is primarily attributed to the fact that I seem to be running leaner instead of richer.
I recently just switched to the stock exhaust manifold & I used new gaskets (used GS gaskets for the header to block). I double checked my torques when I did the re-install. Made the O2 sensors snug.
Mods: K&N Filter, Catback Exhaust, OFT Stg 1 91Oct Tune
Here are a few pulls...
http://datazap.me/u/phantobe/stg1pul...=0&data=1-5-10 3rd Gear
http://datazap.me/u/phantobe/stg1pul...=0&data=1-5-10 2nd gear
http://datazap.me/u/phantobe/stg1pul...=0&data=1-5-10 I think 3rd gear again
http://datazap.me/u/phantobe/stg1kre...5?log=0&data=1 Daily Driving
I was gonna get under the car this weekend to check things out...but any ideas or suggestions to troubleshoot this?
Originally Posted by zeppy View Post
Hi everyone, i switched over to the new OFT maps about a week ago and did a 3rd gear pull. Can someone take a look at the log for me?
from what i can see i'm running a bit rich and some knock from 5400-6800?
Mods: drop in filter, cat back exhaust, oil cooler.
http://datazap.me/u/zeppy/oct-26-stg...=0&data=1-9-14
This guy ^ also ended up having a similar AFR to me @zeppy
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
Old 06-24-2015, 08:35 PM   #2
Kodename47
Kodename47's Avatar
Drives: UK GT86
Change in manifold could do that, if it's not a physical issue then just add some fuel in.
What's your O2 scaling like?
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-24-2015, 09:02 PM   #3
Phantobe
Phantobe's Avatar
I haven't touched any of the scaling just using the OFT Stg 1 91 octane tune. Only I think I did was pull a bit of timing to compensate for knock.
Not really sure why the ECU isn't adding fuel. Like under WOT until about 5k LTFT is 0% while the AFR is not that close to the command AFR.
Old 06-24-2015, 09:18 PM   #4
steve99
use the vgi utility to touch up the maf scaling mainly the open loop, but wont hurt to do both.
Old 06-24-2015, 11:33 PM   #5
Phantobe
Phantobe's Avatar
I guess I'll give it a try, is it okay to do OL scaling before CL scaling?
Old 06-25-2015, 03:02 AM   #6
steve99
normally you do CL first then OL
although your CL looks ok
Old 06-25-2015, 10:49 AM   #7
Phantobe
Phantobe's Avatar
Gotcha...
Is it okay to do 2nd gear pulls for data? Or is 3rd gear preferred (the guide recommends 3rd or 4th), I don't have a lot of stretches of road for 3rd lol.
Old 06-25-2015, 11:15 AM   #8
wparsons
wparsons's Avatar
Did you reflash after swapping manifolds? The trims could still be learning after the swap.
flickr
Old 06-25-2015, 01:25 PM   #9
Phantobe
Phantobe's Avatar
Yep. Ran stg 2 uel when I had uel header in. Swapped to stock. Flashed to factory, ran for a bit. Then flashed to stg 1.
Old 06-25-2015, 03:25 PM   #10
Kodename47
Kodename47's Avatar
Drives: UK GT86
In open loop the commanded and "actual" AFR can be and usually are different. Nothing says they should match up. Either scale the WOT portion of the MAF, which will throw load and therefore ignition timing out, or just make the Open Loop fuel table richer by the same percent that the AFR is "off".
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-25-2015, 03:55 PM   #11
Phantobe
Phantobe's Avatar
I understand they will be different and they won't be exact however in most/all cases I've seen the AFR generally richer than the commanded AFR. My case the opposite is true, which seems to be much rarer.
I'm going to do the OL MAF scaling and see if that fixes the issue. I still think I'm going to get under there and remove the skid pan and make sure everything looks good this weekend. However since I'm running lean @ WOT would it more likely be a fuel or vacuum leak? Or could it be either.
Thanks for the help gents
Old 06-25-2015, 10:30 PM   #12
Phantobe
Phantobe's Avatar
Here's my OL MAF Scaling...
@steve99
Old 06-26-2015, 12:09 AM   #13
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
It looks like it's either 1. a hardware/sensor issue - in which case you should screw with the tune until it's sorted, or 2. It's a Stg1 MAF scale running on Stg2 tune - that's the only time I've seen oft run so lean.
Old 06-26-2015, 02:25 AM   #14
Phantobe
Phantobe's Avatar
I scaled the ol maf and it looks much better, initial impressions. I'll post some logs tomorrow.
I'll double check the tune tomorrow but I think if I'd know very quickly if I was running a stg2 tune on a stock exhaust manifold. I'd imagine you'd get tons of knock occurrences.
If you look at the op that was the only other person I saw with a similar issue.
Installed Cusco Catch can wrong? Running lean goshem Engine, Exhaust, Transmission 17 08-19-2014 03:06 PM
Syste!m too lean bank 1 jonbonazza Issues | Warranty | Recalls / TSB 55 07-05-2014 01:36 AM
lean at idle only woode Forced Induction 5 05-03-2014 04:48 PM
running lean EZWood Engine, Exhaust, Transmission 26 10-18-2013 12:53 PM
Slip+CEL = Bank1 running lean? Trashed675 Issues | Warranty | Recalls / TSB 11 03-28-2013 10:53 PM
