Old 02-24-2016, 04:16 AM   #1
BigBrainedMonkey
BigBrainedMonkey's Avatar
Drives: Subaru BRZ
Running lean at high RPM
Just want to ask you guys for help.
My 2013 BRZ went on the dyno the other day for a tuning session. My tuner found out that my car was running lean at high RPM (around 5K to redline). He tried correcting it but the car would not respond.
From what I've read, it could be caused by a dirty/loose MAF sensor, problem with the intake.
Any of you experience this before? What could be causing this?
List of modifications are pretty basic:
AVO drop-in filter
VDS headers, overpipe and front pipe
Greddy CTS V2
roadtuned using BRZedit
Thanks in advance.
BigBrainedMonkey is offline   Reply With Quote
Old 02-24-2016, 05:46 AM   #2
Kodename47
Kodename47's Avatar
Drives: UK GT86
Load/MAF limits?
.: Stealth 86 :.
Kodename 47 DJ:
Old 10-08-2021, 01:30 AM   #3
Rako
Drives: 2023 GR86 M/T
Did you ever figure it out? I'm having the same issue
Rako is offline   Reply With Quote
Old 10-08-2021, 12:05 PM   #4
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Have you cleaned the MAF?
What mods? Important for people to help you.
Old 10-08-2021, 12:59 PM   #5
tomm.brz
Drives: brz 2017 hksv2
also log if you can
Old 08-30-2022, 04:45 PM   #6
Rako
Late update but maybe this will help someone...
In my logs I noticed that the car started going lean when PI was being cut off at around 5k in favor of DI only. The cause of my problem according to my tuner was a bug in ecutek where it was cutting off fueling when using DI only, so he ended up blending PI and DI all through the WOT range while still mostly using DI for max performance. This solved my issue.
Possible vacuum leak? (Running lean and high fuel trims) nickw14 Engine, Exhaust, Transmission 6 02-10-2023 10:56 AM
Running a bit lean on WOT pull Phantobe Software Tuning 16 06-26-2015 01:41 PM
Installed Cusco Catch can wrong? Running lean goshem Engine, Exhaust, Transmission 17 08-19-2014 03:06 PM
running lean EZWood Engine, Exhaust, Transmission 26 10-18-2013 12:53 PM
Slip+CEL = Bank1 running lean? Trashed675 Issues | Warranty | Recalls / TSB 11 03-28-2013 10:53 PM
