Old 12-31-2015, 12:17 PM   #1
username404
Drives: 2013 BRZ Limited GB 6MT
Driver Side High Beam Not Working
'13 BRZ Limited 6MT
Just tested by swapping headlamps and looks like wiring issue is causing not be able to do high beam on the Driver Side.
If there a fuse or I have to trace the wiring harness?
Thanks.
username404 is offline   Reply With Quote
Old 01-07-2016, 11:25 AM   #2
FT&6
FT&6's Avatar
Drives: FRS Raven 6AT
If you haven't already, first check would be for corrosion on the pins in the pigtail or for a recessed pin on the headlights/pigtail not making contact. Otherwise check the fuses for each high beam in the engine bay fuse box.
FT&6 is offline   Reply With Quote
Old 01-07-2016, 12:24 PM   #3
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by username404 View Post
'13 BRZ Limited 6MT
Thanks.
At least for the FR-S, I know that there is a relay (white/offwhite box) in the fuse box labeled "DRL" that controls both the high beams as well as DRL function, not sure about the BRZ though because it's headlights are OEM hid and LED boomerang DRL. If that relay were the issue then both headlights wouldn't be able to have DRLs or high beams not one. I suggests pulling or tugging on the wires coming from the pins on the connectors with the high beams on to see if it flashes on that side or something.
Old 01-07-2016, 12:40 PM   #4
username404
Just swapped the sides and both work on passenger side only. Looks like wiring issue but not sure where to start yet. I guess connector on wiring hardness.
Old 01-07-2016, 04:37 PM   #5
ryoma
ryoma's Avatar
the high beam is just a solenoid that lowers a plate in the projector to release the full beam. the HID bulb has nothing to do with the high beam actuation. it could be either a bad fuse, or a bad solenoid. I don't think it would be a problem with the actual wiring harness unless you personally messed with it and did something. just hope it's a bad fuse lol since it will cost some $$ to replace the solenoid. you can try speed cycling the high beam in case the solenoid is just some how stuck.
Old 01-07-2016, 05:15 PM   #6
username404
It can't be the solenoid because I took out the unit and connected to the passenger side wiring and it worked.
Old 01-07-2016, 05:45 PM   #7
FRSBRZGT86FAN
I just double checked your fuse box you have the DRL relay that controls the high beams as well like in the FRS, looks like it's a connector or wiring harness issue, and @ryoma there is no "fuse" for the headlights it's a relay and resistor setup :
I'd check all the pins on the connector, when I was doing the DRL mod for my winjets on the FR-S I messed up a pin a bit and the high beams would only engage on one side until I jiggled the wiring harness and in turn the pin in the connector to the right position. I think you can now narrow this issue down
Old 05-03-2016, 10:14 PM   #8
username404
YEP, IT WAS THE FUSE =)
Old 05-03-2016, 10:17 PM   #9
FRSBRZGT86FAN
Fuse or relay? Also did it take 4 months to get this corrected?
Old 05-08-2016, 01:31 PM   #10
username404
Yep. Been busy and traveling and finally got back to work on the car. Story of my life.
Sent from my LG-H950 using Tapatalk
Old 05-08-2016, 01:33 PM   #11
FRSBRZGT86FAN
Understandable was just curious, I'm in college so I understand what it's like I don't see my car for 5 months ever yea and then only get into it for a month.
Old 05-08-2016, 01:36 PM   #12
username404
Yes....life gets harder after college bro. Enjoy your time there. Wish I'm back in school. LoL
Old 07-11-2017, 07:58 PM   #13
wrb
frank
wrb's Avatar
Drives: Subaru BRZ WRB
sorry to bring up the old thread.. but i am having same problem.
was it the high beam fuse that you replaced to fix the problem? or was it DIM relay ?
2013 SUBARU BRZ WRB LIMITED M/T
Los Angeles, CA
Build Photo Album - http://bit.ly/brz_wrb
SoCal LA 86 Club Member
wrb is offline   Reply With Quote
Old 08-02-2017, 10:19 AM   #14
Icecreamtruk
Drives: Track preped NA FRS
More necro. I have the same problem. Fuse was out, replaced it, light works for a few minutes then goes off, checked again and fuse out, so something is causing the fuse to burn. I changed the DIM relay, since its cheap and just in case, the same thing. Driver side only as well. I think its the wiring, no other way around it. I havent modded/touched my lights but I track the car pretty hardcore so maybe all of that mouvement got something loose (or me taking off and on the bumper).
Edit: I mesured the resistance on both lights, they both measure the same. I measured the current and voltage on both sides, same measurement. I swapped sides with the bulbs, same result. Its in the cable between the fuse box and the lightbulb, where exactly I dont know.
Icecreamtruk is offline   Reply With Quote
Right low beam not working. zman Issues | Warranty | Recalls / TSB 13 03-14-2016 08:08 PM
Low Beam Lights Not Working acwells25 Issues | Warranty | Recalls / TSB 2 02-03-2016 10:46 AM
HID vs LED Low/High beam along with DLR? xFury Cosmetic Modification (Interior/Exterior/Lighting) 5 12-15-2015 11:15 AM
Simple Shut Window Feature Not Working on Driver's Side Gimagination Issues | Warranty | Recalls / TSB 21 05-08-2013 11:59 AM
