Old 12-12-2015, 02:02 PM   #1
acwells25
Drives: 2013 Scion FR-S (Raven Black)
Low Beam Lights Not Working
I put my car away for storage a month or so ago and neglected to put the battery on tender, killed it next time I tried to start the car, seems ever since then my Mirimoto 55W (Lo Beams) working in DRL mode (first two switches on the lights) but when I switch to the third function being the low-beam setting...they go out...so it obviously isn't the bulb or the ballast or whatnot because it's lighting up in the first two settings...and yes I've check the two 15AMP fuses under the hood for lo beam left and right hand side, both fuses appear to be fine. I'm wondering is there a controller or relay for the low beams that I may have thrashed in killing my battery?
Thanks,
Andrew
acwells25 is offline   Reply With Quote
Old 12-13-2015, 03:03 AM   #2
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Thanks,
Andrew
1) IDK why there's a need to run 55W HIDs in this car, it's bad for the electrical harnesses anyway even with the relay
2) I would contact the vendor you bought them from, otherwise contact morimoto directly
Old 02-03-2016, 10:46 AM   #3
Nikki95
Nikki95's Avatar
Drives: 2013 pearl white FR-S
Thanks,
Andrew
Hello Andrew I'm having the same issue as you did! I'm wondering what you did to fix it?
Nikki95 is offline   Reply With Quote
Valenti Tail Lights - Running Lights not working at all Antstronaut Cosmetic Modification (Interior/Exterior/Lighting) 12 08-10-2017 07:11 AM
Right low beam not working. zman Issues | Warranty | Recalls / TSB 13 03-14-2016 08:08 PM
Lights not working. nguyen_er Cosmetic Modification (Interior/Exterior/Lighting) 14 04-10-2015 12:35 AM
*PHASTEK* High / Low Beam Fog Lights for the FR-S & BRZ PhastekSport Exterior Parts - Lighting 35 01-06-2014 10:23 AM
Parking/fog lights not working THEWAKLER Cosmetic Modification (Interior/Exterior/Lighting) 2 10-09-2013 08:26 PM
