Old 04-24-2015, 04:25 PM   #1
zman
zman's Avatar
Drives: scion frs
Right low beam not working.
Ok so yesterday my hid right low beam went out, so i try to put the oem bulb there but it wont turn on. Also I switched the ballast of the left side to the right and nothing. Does anyone know what the issue might be ? Thanks.
Sorry if this is a double post.
zman is offline   Reply With Quote
Old 04-24-2015, 04:35 PM   #2
Boostedpro
Can't remember off the top of my head but I believe the underhood fuse box has seperate fuses for driver and passenger side headlights. When the bulb/ballast went it may have popped the fuse.
Boostedpro is offline   Reply With Quote
Old 04-24-2015, 04:58 PM   #3
zman
zman's Avatar
Drives: scion frs
Ok thanks ill try that when I get a chance
Old 04-24-2015, 04:59 PM   #4
zman
zman's Avatar
Drives: scion frs
Also do you know what the fuse is marked as?
Old 04-24-2015, 05:11 PM   #5
Boostedpro
It is labeled as "H-LP RH LO" it should be a 15amp fuse according to the wiring diagram. Don't know for sure if that is how it is labeled on the fusebox though.
Old 04-24-2015, 05:29 PM   #6
kchar
Because Racecar
kchar's Avatar
Drives: 2014 Scion FR-S
Wow this exact thing happened to me a week or so ago. Mine ended up being a blown fuse. It's a blue 15amp for sure. There's a replacement extra already in the fuse box. The back of the fuse cover will show you where it is.
kchar is offline   Reply With Quote
Old 04-24-2015, 08:44 PM   #7
zman
zman's Avatar
Drives: scion frs
Ok thanks guys 😀 im glad it's just a fuse because I was about to take it to my dealer lol.
Old 04-25-2015, 01:50 PM   #8
zman
zman's Avatar
Drives: scion frs
All fixed 😊
Old 03-13-2016, 10:03 PM   #9
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
Originally Posted by zman View Post
All fixed 😊
Any pics of the fuse think I just blew mine also do we get replacement fuses if so where ?
Sent from my SM-G935T using Tapatalk
SoCal80six is offline   Reply With Quote
Old 03-14-2016, 01:43 AM   #10
zman
zman's Avatar
Drives: scion frs
We do get replacements, I will try to get a picture tomorrow but it says it on the box where it's located
Old 03-14-2016, 01:45 AM   #11
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
OK thanks if you can get pics that would be perfect appreciate it!!
Old 03-14-2016, 03:06 PM   #12
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
Why would only one side pop a fuse ?
Old 03-14-2016, 07:55 PM   #13
zman
zman's Avatar
Drives: scion frs
Still not home so I couldn't take a picture but this one shows the location of it. 20amp and it's blue.
Old 03-14-2016, 08:08 PM   #14
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
Alright thanks bro really appreciate it!!
Crash Beam afishl1 Exterior Parts (Aero, Lighting, Etc.) 1 04-12-2015 12:51 PM
Hi beam indicator Norkoastal BRZ First-Gen (2012+) — General Topics 4 12-10-2013 12:53 PM
DRL or high beam or both? jacobzking Cosmetic Modification (Interior/Exterior/Lighting) 5 06-09-2013 03:09 PM
HID and high beam use gatorbushmen Cosmetic Modification (Interior/Exterior/Lighting) 4 04-19-2013 04:56 PM
Low beam on indicator? percyng CANADA 5 10-10-2012 04:47 PM
