Old 04-10-2013, 06:02 PM   #1
Gimagination
Girls ♥ FR-S
Gimagination's Avatar
Simple Shut Window Feature Not Working on Driver's Side
Do you know how there is this window feature (http://www.scion.com/cars/FR-S/featu...window_feature) that lowers the window just a bit to allow the air to escape as you close the door so it's easier for you to close? Well, mine isn't working. It makes me mad because I'm a girl and I close the door very gently and it never closes because the air is trapped.
The passenger side does work, but not the driver's. I already looked it up in here and in the manual but the only quick fix I found was to reset the automatic up/down feature (http://www.ft86club.com/forums/showthread.php?t=19731). I reset it but since it's not the same issue it didn't fix it.
I called the dealership and since it never worked since the day I bought it (2 weeks ago) they said it might have been that no one ever programmed it.
Has anyone had the same issue? I'm bringing it to the dealership Friday and I'm hoping I can get it fixed on my own before then because whatever they do I don't want them to open my door panel
Gimagination is offline   Reply With Quote
Old 04-10-2013, 06:16 PM   #2
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
My bad just read the rest of your post. I do remember others having the same issue and the reset fixing it for them tho.
if not I'm sure the ft86 collective here will think of something.
btw I'm a guy and I shut my door very light too but its cause I don't want to harm my precious
have you tried the window reset yet?
Put car to on, engine off. Push and hold button down until window rolls down and you hear a click. Then hold window button up until it rolls up and you hear a click
http://www.ft86club.com/forums/showt...t=window+reset
Out of the FRS game
Mr.Jay is offline   Reply With Quote
Old 04-10-2013, 07:21 PM   #3
strat61caster
strat61caster's Avatar
BTW it has nothing to do with the air pressures (50 plus years of cars with wind up windows having zero problems) it has to do with the frameless windows fitting into the seals the car was designed with, otherwise the windows will push and pull the seals decreasing their life.
If the window reset mentioned above doesn't work then you'll have to talk to the dealer and have it covered under warranty.
ineedyourdiddly
Old 04-10-2013, 09:11 PM   #4
Gimagination
Girls ♥ FR-S
Strat61 that makes sense. I thought it was because of the air trapped. Thanks for the info!
Mr. Jay I did try that and it didn't work
Old 04-10-2013, 09:16 PM   #5
Ethereal
Drives: 2012 VW GTI
Noticed this today at the dealership, when i opened the driver side door, the window came down a bit, when i closed the door it went back up, all on its own.
Assuming your window still moves up and down manually with the power button?
Ethereal is offline   Reply With Quote
Old 04-10-2013, 09:18 PM   #6
Gimagination
Girls ♥ FR-S
Yes it does, absolutely nothing wrong with the window besides when I open the door.
Old 04-10-2013, 09:20 PM   #7
Ethereal
Drives: 2012 VW GTI
Put car to on, engine off. Push and hold button down until window rolls down and you hear a click. Then hold window button up until it rolls up and you hear a click.
Old 04-10-2013, 09:21 PM   #8
Gimagination
Girls ♥ FR-S
Did that more than ten times at different times of the day and still didn't fix the issue
Old 04-10-2013, 09:27 PM   #9
Ethereal
Drives: 2012 VW GTI
That sucks, sounds like a dealer appointment is in order if you really like that feature. Crossing my fingers for you if you go that route that they dont more harm than good like take off the panel and break clips or something
Old 04-10-2013, 09:29 PM   #10
Gimagination
Girls ♥ FR-S
Yeah me too, she's my baby!!! Thanks for replying and trying to help! I appreciate it :-)
Old 04-10-2013, 09:43 PM   #11
Ethereal
Drives: 2012 VW GTI
Youre welcome One last thing, are you trying the reset with the door open or closed? I think it has to be closed to work.
Old 04-10-2013, 11:06 PM   #12
BRZnut
Drives: BRZ DGM Limited
The only people that post problems with this feature were those who had snow and ice on the windows this past winter. But seeing you're from Florida rules that out!
Old 04-12-2013, 11:09 AM   #13
Gimagination
Girls ♥ FR-S
I did both, door closed and door open. And yeah I noticed some relationship between window not working and icy places.
Getting out from the dealership now. They had to take the door apart, it seems like there was a disconnected wire inside. At least it's now fixed :-)
Old 04-12-2013, 11:58 AM   #14
strat61caster
It's not a "feature" you can like or dislike, it's the design of the car and not fixing it will result in prematurely worn window seals that will probably leak like a sieve.
ineedyourdiddly
closing, simple shut, simple shut window, window, windows
Auto-Up/Down and Passenger Window Not Working chanomatik Issues | Warranty | Recalls / TSB 106 05-09-2021 01:25 AM
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 06:09 PM
Scratches on Outside of Driver's Window NewmarketBRZ Issues | Warranty | Recalls / TSB 56 09-26-2018 04:57 PM
WTB driver's side stock projector Jacob G. Exterior Parts (Aero, Lighting, Etc.) 2 02-28-2013 09:21 PM
Issue with Simple Shut Window Feature Jayp Issues | Warranty | Recalls / TSB 5 07-26-2012 11:18 PM
