Old 12-25-2015, 06:05 PM   #15
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
The oil pressure switch is not the issue, I've been running my car for 6 months with the plug disconnected. No codes, no lights, nothing out of the ordinary. Something else is going on here.
Decay107 is offline   Reply With Quote
The Following 2 Users Say Thank You to Decay107 For This Useful Post:
Dream20b (12-26-2015), Ultramaroon (12-26-2015)
Old 12-25-2015, 06:08 PM   #16
I wonder if you don't have a dirty injector stuck open? o.0
Old 12-25-2015, 06:19 PM   #17
Agreed, however if the wire were disconnected we still couldn't rule out an oil starvation issue. I'm still wondering about the ABS code.
The fuel in the crankcase is interesting. The very first fuel-injected engine I revived was my dad's 75 beetle. One of the injectors shorted internally which threw them all hard over and flooded the cylinders to the point of hydro-lock.
Decay107 (12-26-2015)
Old 12-25-2015, 06:22 PM   #18
Is your oxygen sensor soaked?
Old 12-26-2015, 12:15 AM   #19
Dream20b
Y u do dis?
Haven't gotten far yet, will check stuff tomorrow
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline   Reply With Quote
The Following User Says Thank You to Dream20b For This Useful Post:
Old 12-26-2015, 11:22 AM   #20
Dream20b
Y u do dis?
Engine turns over by hand, no fuel flooded the o2 sensor
Dat Hot Lava Doe
Old 12-26-2015, 03:10 PM   #21
Turn on the ignition but don't crank. Work the gas pedal. Does the TB respond? You'll hear it.
Drain oil into a clean pan and swish a magnet around in it. Anything that shouldn't be there?
Disconnect the blower and turn it back and forth by hand. Does it feel ok? Anything other than buttery smooth is a problem.
I'm at a loss. Might be time to troubleshoot per the service manual, Techstream and all.
@Decay107? Anyone else care to chime in?
Old 12-26-2015, 06:04 PM   #22
Dream20b
Y u do dis?
I'll check those things now
Dat Hot Lava Doe
Old 12-26-2015, 06:08 PM   #23
Dream20b
Y u do dis?
Blower Feels good. Definatley not the problem. I can't hear the Throttle body opening and closing, I'll check that out in further detail before draining the oil.
Dat Hot Lava Doe
Old 12-26-2015, 06:18 PM   #24
Very good. You have a hard failure to chase. I agree, leave the oil alone for now.
If it is contaminated with fuel, get it out of there before running the engine because it thins the oil and, if E85, is a little corrosive.
Old 12-26-2015, 06:21 PM   #25
Dream20b
Y u do dis?
Was poking around the MAF sensor and found the wires have been rubbed into by the belt, some wires missing. I think I've found the problem. FML.
Dat Hot Lava Doe
whataboutbob (12-30-2015)
Old 12-26-2015, 06:55 PM   #26
Shit. Did the clip come out the last time the belt failed? It's actually good news. Those wires can be spliced and re-taped fairly easily. You're in a much better predicament than if it were a spun bearing. :P
Old 12-26-2015, 06:56 PM   #27
Dream20b
Y u do dis?
yeah we'll see. I'll have to get it towed again because I cannot do electrical work, lol.
Dat Hot Lava Doe
Old 12-26-2015, 06:59 PM   #28
Dream20b
Y u do dis?
also it looks like the throttle body side wiring harness was somewhat loose. Going to try reconnecting that, and getting a new belt and some electrical tape. I'll update as soon as I know.
Dat Hot Lava Doe
installing sensor/adapter for oil temp and pressure - how? pcuerpo Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 06-29-2018 06:40 AM
Where BRZ ATM pressure sensor?? silviahrc Engine, Exhaust, Transmission 3 12-12-2015 03:28 AM
Beta Testers Wanted- Fuel Pressure Sensor GSpeed Tracking / Autocross / HPDE / Drifting 5 08-16-2015 04:03 PM
Oil pressure and Oil Temp sensor - where did you mount them and how philooo Engine, Exhaust, Transmission 11 05-29-2015 02:41 AM
DI pressure sensor calibration? - standalone ElectronSpeed Engine, Exhaust, Transmission 0 02-27-2013 11:38 PM
