Old 12-24-2015, 12:06 AM   #1
Dream20b
Y u do dis?
Broken Oil pressure sensor?
Okay, So tonight I was driving and about 5 minutes into my drive I heard this banging noise, it was very loud and increased and decreased with RPMs. I've managed to get home with the car but not until after calling a tow truck.
Long story short, Car chugged and then died, refuses to start at all. I did some searching in the engine bay and found the wiring part in the Attached image to be broken. Does anyone know what that piece is called? I think its the Oil Pressure Sensor. If this is really broken, could this cause a no-start condition? Car still doesn't start, no clicks, no nothing. Lights on dash come on and the battery is good.
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline   Reply With Quote
Old 12-24-2015, 01:15 AM   #2
[YOYO]
Amazing Member
[YOYO]'s Avatar
Drives: 2014 Whiteout FR-S
Yah, that looks like it could be the oil pressure sensor, but the pounding / banging noise sounds like it's something else. Any warning lights come up on the dash (CEL / oil)? Did the loud sound seem like it was something from within the engine / internal (although, chances are it definitely was, seeing as your car refuses to start).
Maybe someone who's had a similar issue can chime in. I've had issues with oil pressure sensors on one of my older cars in the past, but they never cut the engine out, so I would doubt that is the issue here.
[YOYO] is offline   Reply With Quote
Old 12-24-2015, 01:31 AM   #3
Ultramaroon
not playing cards
Ultramaroon's Avatar
Yeah, that's the oil pressure switch. If it was disconnected you would have no warning light for loss of oil pressure. Bang and knock sounds like a thrown rod or spun bearing. Likely due to oil starvation.
How much oil on the dipstick?
Old 12-24-2015, 02:40 AM   #4
steve99
Op dude you might want to include mods, it appears you running a sprintex SC kit on E85 judging by your other posts
that oil pressure sender looks ok,is wire still connected.
knocking\banging sounds pretty terminal.
Old 12-24-2015, 02:44 AM   #5
Ultramaroon
not playing cards
Ok, as Steve said, "More info."
Old 12-24-2015, 01:16 PM   #6
Dream20b
Y u do dis?
Mods Sprintex supercharger 210 kit with e85 tune from moto east. Tomei El header, perrin 2.5 in resonated exhaust and 70mm pulley. Codes c1201, c1234, u0100
Dat Hot Lava Doe
Old 12-24-2015, 03:14 PM   #7
steve99
Yep looks like you have some form of electrical problem as well
could be a simple as a dead battery
C1201 ABS rear valve failed
C1234 ABS module error
U0100 General communications fault between ECM and PCM power train control module
seem a bit unrelated unless battery has failed or SC belt has let go and damaged wiring or similar.
As for the knocking/banging that does not sound good, it possible it may be due to control module issues but sound more of a mechanical problem.
Old 12-24-2015, 03:33 PM   #8
Ultramaroon
not playing cards
Hmmm... I would need eyes and hands on to get any further.
Old 12-24-2015, 03:44 PM   #9
Dream20b
Y u do dis?
I'll be wrenching tonight
Dat Hot Lava Doe
Old 12-24-2015, 04:59 PM   #10
BRZnut
Drives: BRZ DGM Limited
keep us updated. Good luck
Old 12-24-2015, 06:41 PM   #11
Dream20b
Y u do dis?
Smells faintly like e85 when I pull the dipstick. No leaks under the car after sitting 12 hours. Oil level is normal, maybe a tad high.
Dat Hot Lava Doe
Old 12-25-2015, 11:30 AM   #12
Dream20b
Y u do dis?
Found some pieces of belt near the rear of the engine bay. However, as far as I can tell, the belt is till in tact and I can trace it all the way around the top half of the motor. this piece of belt may be from a previous shredded belt.
Dat Hot Lava Doe
Old 12-25-2015, 02:15 PM   #13
Ultramaroon
not playing cards
Did you reconnect that lead to the oil pressure switch before you took the photo, or did you take that snapshot as-is?
Old 12-25-2015, 03:38 PM   #14
Dream20b
Y u do dis?
as is
Dat Hot Lava Doe
installing sensor/adapter for oil temp and pressure - how? pcuerpo Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 06-29-2018 06:40 AM
Where BRZ ATM pressure sensor?? silviahrc Engine, Exhaust, Transmission 3 12-12-2015 03:28 AM
Beta Testers Wanted- Fuel Pressure Sensor GSpeed Tracking / Autocross / HPDE / Drifting 5 08-16-2015 04:03 PM
Oil pressure and Oil Temp sensor - where did you mount them and how philooo Engine, Exhaust, Transmission 11 05-29-2015 02:41 AM
DI pressure sensor calibration? - standalone ElectronSpeed Engine, Exhaust, Transmission 0 02-27-2013 11:38 PM
