Old 12-10-2015, 04:11 AM   #1
silviahrc
Where BRZ ATM pressure sensor??
my brz ATM always 126 kpa
who know this sensor?
silviahrc is offline   Reply With Quote
Old 12-11-2015, 05:04 AM   #2
steve99
I suspect the Atmospheric Pressure information is derived from the MAP (manifold pressure sensor)
89420M SU00300419 SENSOR ASSY, AIR PRESSURE
http://www.toyotapartswebstore.com/a...01-264410.html
Old 12-11-2015, 05:48 AM   #3
Kodename47
Kodename47's Avatar
Drives: UK GT86
Going on the ECUtek options, non-USDM use the CPC sensor. I guess that USDM use the MAP sensor.
.: Stealth 86 :.
Kodename 47 DJ:
Old 12-12-2015, 03:28 AM   #4
silviahrc
I will only use ecuflash,so maybe I try use the ecuflash fix?
I trying OEM MAP &3BAR MAP
always 126kPa
but other brz &86 & FRS are 101kPa
so I think maybe my ATM sensor broken? or MAP broken?
someone there are other ways?
who ECU PINOUT? maybe I can replace ATM resistance sensor signals?
installing sensor/adapter for oil temp and pressure - how? pcuerpo Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 06-29-2018 06:40 AM
Beta Testers Wanted- Fuel Pressure Sensor GSpeed Tracking / Autocross / HPDE / Drifting 5 08-16-2015 04:03 PM
Oil pressure and Oil Temp sensor - where did you mount them and how philooo Engine, Exhaust, Transmission 11 05-29-2015 02:41 AM
DI pressure sensor calibration? - standalone ElectronSpeed Engine, Exhaust, Transmission 0 02-27-2013 11:38 PM
