Old 11-12-2015, 11:53 PM   #1
pcuerpo
pcuerpo's Avatar
Drives: Toyota 86
Send a message via ICQ to pcuerpo Send a message via Yahoo to pcuerpo
installing sensor/adapter for oil temp and pressure - how?
i currently have a Perrin Oil Cooler kit and i want to install an oil temp and pressure gauge. if i understand correctly, you need to install a sandwich plate or sensor adapter so info can be read and sent to the gauges i have. how do i do that when i have the Perrin kit installed? do i remove the oil filter spacer?
i hope those with the Perrin kit can share what they did so they can monitor oil temp and pressure
btw, i plan to get Defi gauges if this info will help in determining what to do
thanks!
2013 Toyota 86
Sterling Silver Metallic
IG: @pcuerpo.images
pcuerpo is offline   Reply With Quote
Old 11-13-2015, 10:50 AM   #2
Wyattkb
Drives: 2014 Whiteout FRS
Check out this thread for some info.
http://www.ft86club.com/forums/showthread.php?t=82414
Wyattkb is offline   Reply With Quote
Old 12-20-2016, 10:47 PM   #3
Brzerker
Brzerker's Avatar
Drives: World Rally Blue BRZ
Apologies for thread revival.
I am also looking for a solution for the Perrin Oil Cooler setup as it does not come with sensor ports. Did anyone stack the TRD oil filter sandwich sensor plate with long term useage already? Am worried by stacking plates, it might be prone to leakages.
Brzerker is offline   Reply With Quote
Old 01-06-2017, 03:53 PM   #4
BatStig
Some say.....
BatStig's Avatar
Drives: 2007 Subaru Impreza 2.5i
@Brzerker instead of stacking, I replaced the Perrin sandwich plate with this TRD one.
http://www.ft86speedfactory.com/trd-...l#.WHADYuz4-Hs
BatStig is offline   Reply With Quote
Old 01-06-2017, 05:32 PM   #5
TheDetailer718
TheDetailer718's Avatar
Drives: 2013 Subaru BRZ
I just recently installed an Oil Temp Gauge. I used an oil galley adapter plug. The oil galley plug is right by the throttle body on the block.
This is what i used.
https://www.rallysportdirect.com/par...il-galley-plug
TheDetailer718 is offline   Reply With Quote
Old 01-08-2017, 10:35 PM   #6
Brzerker
Brzerker's Avatar
Thanks. Looking at the product page, it seems the sandwich plate has the sensor ports only. What sandwich plate did u stack above to adapt the fluid hoses ?
Old 01-09-2017, 04:38 PM   #7
BatStig
Some say.....
BatStig's Avatar
That is the Mocal thermostatic sandwich plate that comes with most of the oil cooler kits out there.
Old 01-10-2017, 05:34 AM   #8
Brzerker
Brzerker's Avatar
So it's the same plate as the one on my Perrin oil cooler. Thanks
Old 05-21-2017, 08:29 PM   #9
LJ53
Drives: FRS
How exactly did you do this? i have the FBM kit which is identical in the oil filter area, and i bought the TRD sandwich plate. The problem is that the M20 extension piece is too short. What did you use? I've read some people are finding the extension that fits just the mocal thermostatic plate to thread onto the TRD one, but i cannot find it anywhere.
LJ53 is offline   Reply With Quote
Old 05-22-2017, 08:22 AM   #10
BatStig
Some say.....
BatStig's Avatar
I ordered the extension for the Mocal plate from www.batinc.net .
Old 05-22-2017, 10:20 AM   #11
Trust86
Drives: 2016 Halo FRS
The oil temp reads low in that location. I changed mine to the sandwich plate and the oil temp readings were much better.
Trust86 is offline   Reply With Quote
Old 01-30-2018, 03:12 AM   #12
Brzerker
Brzerker's Avatar
Do you happen to have the p/n for the M20 extension?
Old 02-02-2018, 03:35 PM   #13
BatStig
Some say.....
BatStig's Avatar
It is the standard length extension screw for an M20 filter. The part number is ES20.
Old 02-04-2018, 08:52 PM   #14
Brzerker
Brzerker's Avatar
Thank you!!
pressure and temp oil in this car? pepe Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 08-25-2015 05:02 PM
Oil pressure and Oil Temp sensor - where did you mount them and how philooo Engine, Exhaust, Transmission 11 05-29-2015 02:41 AM
Installing oil pressure/temp probes xwd Engine, Exhaust, Transmission 12 03-14-2015 12:07 AM
Help Installing Oil Temp Gauge k.houan Engine, Exhaust, Transmission 1 11-10-2014 11:57 PM
Addition of a radiator hose sensor temp adapter & coolant bleeding FutureFT86 Engine, Exhaust, Transmission 9 07-21-2014 11:50 PM
