Old 09-07-2015, 07:17 AM   #15
aagun
Drives: 86
Originally Posted by cdrazic93 View Post
Havent they also caused cams to go out of alignment?
camshafts aee in good condition there are no Scratchs or porting marks that let the cam clearance go far .
aagun is offline   Reply With Quote
The Following User Says Thank You to aagun For This Useful Post:
cdrazic93 (09-07-2015)
Old 09-07-2015, 01:03 PM   #16
nelsmar
You have me curious now. I am going to have to check the clearance on my spare block before I tear it down next week. I know a local that is getting a lot of noise when the DI system fires up. I wonder if his lash has fallen far out of spec. It's a shame that you have to pull the block just to check the clearances. Flat engines can be rather painful to deal with.
I'm sure if someone was very dedicated you could do it without pulling the block but it would probably take the same amount of time to pull it.
My flickr - Canibeat
Local magazine scout
The Following 3 Users Say Thank You to nelsmar For This Useful Post:
aagun (09-07-2015), cdrazic93 (09-07-2015), CSG Mike (10-03-2015)
Old 09-08-2015, 07:27 PM   #17
aagun
Drives: 86
because of below
Old 09-08-2015, 07:34 PM   #18
aagun
Drives: 86
Astroboy (10-03-2015)
Old 09-08-2015, 09:25 PM   #19
Sargy
Long Distance Driver
Sargy's Avatar
Well that escalated quickly...
Good luck man,
Sargy is offline   Reply With Quote
The Following 2 Users Say Thank You to Sargy For This Useful Post:
aagun (09-09-2015), Astroboy (09-28-2015)
Old 10-03-2015, 12:57 AM   #20
Astroboy
Astroboy's Avatar
Drives: None
Originally Posted by aagun View Post
That last picture, is that melted sealant, or did you reseal it ant that's just fresh sealant.?
Astroboy is offline   Reply With Quote
Old 10-03-2015, 04:51 PM   #21
aagun
Drives: 86
sorry about it
i reseal it as it shown in last photo
the leaks came from camshafts holder and from bottom of front cover and i apply sealant without rebuilt the engine or remove any parts
after few days i check it and there are no leaks , so it is work ^^ and save $$
Old 10-03-2015, 08:53 PM   #22
Astroboy
Astroboy's Avatar
Drives: None
sorry about it
I don't mean to bother, but let me get this straight, you're telling me that you basically just put sealant over where it was leaking and it stopped? No tearing of the engine correct? If I'm reading this correctly, that's fucking bad ass!
Sent from my LG-D850 using Tapatalk
The Following User Says Thank You to Astroboy For This Useful Post:
aagun (10-03-2015)
Old 10-03-2015, 10:24 PM   #23
aagun
Drives: 86
yes that it
Oil Leak at Camshaft Timing Controler Cal3000 Issues | Warranty | Recalls / TSB 17 10-03-2015 12:38 PM
camshaft CLEARANCE aagun Software Tuning 1 09-05-2015 08:49 AM
Camshaft Teaser... Carolina Dyno Forced Induction 7 07-16-2015 07:38 PM
Camshaft Timing Oil Control Assembly smellslikecurry Engine, Exhaust, Transmission 0 12-21-2014 01:10 AM
New TSB for camshaft sensor whitefrs Issues | Warranty | Recalls / TSB 13 03-11-2014 03:54 PM
