Old 09-05-2015, 07:41 AM   #1
aagun
Drives: 86
camshaft CLEARANCE
hey 86 owners
i had strange clicks from 1# 3# piston side . i think that clicks because of high pressure pump . but day by day and after long high way drive i hear it a a lot . that sound scared me . so Decided Analysis the issue starting disconnect the DI system by using tech stream. whats happened here is the pump stop clicking and that car runs with port fueling system . the clicks from right side shows up and it say i and problem here . OK that worried me and the game start .
engine works from 29/11/2012 with 130k km on clock
- removed the engine
-stand the engine
- remove valve cover
- calculate cam clearance
i found my cam aliment is out of limit as shown blow
limit
intake 0.10 mm - 0.16mm
exhaust 0.21 mm - 0.27mm
what i am looking for is can i use the engine with that issue and keep it without fix the clearance .
aagun is offline   Reply With Quote
Old 09-05-2015, 07:49 AM   #2
aagun
Drives: 86
delete plz
Camshaft timing oil control valve assembly smellslikecurry Want-To-Buy Requests 11 04-12-2017 04:36 PM
Oil Leak at Camshaft Timing Controler Cal3000 Issues | Warranty | Recalls / TSB 17 10-03-2015 11:38 AM
Camshaft Teaser... Carolina Dyno Forced Induction 7 07-16-2015 06:38 PM
Camshaft Timing Oil Control Assembly smellslikecurry Engine, Exhaust, Transmission 0 12-21-2014 12:10 AM
New TSB for camshaft sensor whitefrs Issues | Warranty | Recalls / TSB 13 03-11-2014 02:54 PM
