Old 09-05-2015, 07:48 AM   #1
aagun
Drives: 86
camshaft CLEARANCE
hey 86 owners
i had strange clicks from 1# 3# piston side . i think that clicks because of high pressure pump . but day by day and after long high way drive i hear it a a lot . that sound scared me . so Decided Analysis the issue starting disconnect the DI system by using tech stream. whats happened here is the pump stop clicking and that car runs with port fueling system . the clicks from right side shows up and it say i and problem here . OK that worried me and the game start .
engine works from 29/11/2012 with 130k km on clock
- removed the engine
-stand the engine
- remove valve cover
- calculate cam clearance
i found my cam aliment is out of limit as shown blow
limit
intake 0.10 mm - 0.16mm
exhaust 0.21 mm - 0.27mm
what i am looking for is can i use the engine with that issue and keep it without fix the clearance .
aagun is offline   Reply With Quote
Old 09-05-2015, 10:08 AM   #2
R2
Alas! I came in here expecting a good clearance sale on camshafts.
R2 is offline   Reply With Quote
Old 09-05-2015, 10:18 AM   #3
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Same.
Good luck on your issue OP.
Freeman is offline   Reply With Quote
Old 09-05-2015, 03:06 PM   #4
humfrz
Did you torque the cam shafts down ??
Then check the clearance.
humfrz
Old 09-06-2015, 09:20 AM   #5
aagun
Drives: 86
humfrz
yes as repair manual say 360
Old 09-06-2015, 09:48 AM   #6
FirestormFRS
Did you check the other side for comparison?
FirestormFRS is offline   Reply With Quote
Old 09-06-2015, 11:47 AM   #7
aagun
Drives: 86
this is what i am doing now
Old 09-06-2015, 01:55 PM   #8
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
In rare cases check your AVCS sensor as those can go bad and have effected a few people on here.
Old 09-06-2015, 02:11 PM   #9
nelsmar
The OP is talking about clearances... Not a sensor related input. This is a physical measured value that he measured using feeler gauges.
My flickr - Canibeat
Local magazine scout
Old 09-06-2015, 06:04 PM   #10
aagun
Drives: 86
left side
it is bad clearance
Old 09-06-2015, 06:30 PM   #11
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by aagun View Post
left side
it is bad clearance
What are the ~200 numbers a measurement of?
Old 09-06-2015, 07:10 PM   #12
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Havent they also caused cams to go out of alignment?
Old 09-06-2015, 10:53 PM   #13
FirestormFRS
That'd be the cam position where he checked the clearance I believe.
I'd say those measurements are probably ok .02mm could be normal wear.
Old 09-07-2015, 06:11 AM   #14
aagun
Drives: 86
that number is standard shim size
Oil Leak at Camshaft Timing Controler Cal3000 Issues | Warranty | Recalls / TSB 17 10-03-2015 11:38 AM
camshaft CLEARANCE aagun Software Tuning 1 09-05-2015 07:49 AM
Camshaft Teaser... Carolina Dyno Forced Induction 7 07-16-2015 06:38 PM
Camshaft Timing Oil Control Assembly smellslikecurry Engine, Exhaust, Transmission 0 12-21-2014 12:10 AM
New TSB for camshaft sensor whitefrs Issues | Warranty | Recalls / TSB 13 03-11-2014 02:54 PM
