86SPEED
Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > FT86CLUB Shared Forum > Member's Car Journals
Old 03-23-2014, 09:59 PM   #1
nelsmar
Arrow nelsmar's rebuild thread.
I figured it was about time I started a build thread (rebuild thread?) as I am constantly text, pm’s, and emails asking what’s new with my build! So I figured I would finally jump on it and get one going!
As many of you know I had an engine failure a while back. There are a numberer of threads on it including a tear down thread. My previous build was a vortech supercharged stock motor pushing out 360WHP on E85. However due to tuning issues I ended up with engine failure throwing a rod out of the block.
Waiting for a tow truck...
Oddly I have an amazingly low number of photos of my car. Considering I shoot professionally I am not quite sure how that happened. Oddly enough the majority of the photos of my car are of it sitting on a flat bed. HAH! Once it runs I’ll hopefully jump in and actually take photos of the car moving forward.
I decided to overbuild my engine for my own power goals. I honestly just wanted a 300-350WHP daily driven small RWD sports car. With my previous setup I was quite pleased and felt the power was more than needed. This car won’t be a drag queen. I enjoy canyon carving and spirited drives and fully plan on doing light track days once the car is running again. During my build I tried to pick a turbine that would fall in the efficiency range of the high 300’s WHP keeping well in the efficiency range to keep my charge temps low for track days. I also wanted to make sure I had something that could handle 400-500+HP on E85 for occasional joy. If I ever get bored I tried to make sure I had enough room to bump the power up without having to do a full tear down. At one point I was going to sleeve and do a full valve setup and port job but then I realized I would be dropping out of the efficiency range for my power desires as I would like to enjoy the car at the track and a 300WHP FRS is well beyond my driving skill.
Ideally I want to rebuild the car and keep it looking & sounding as near stock as possible. I want to have a little bit of an exhaust tone, but very minimal. More so just a slight bit of sound at idle. I quite enjoyed my last setup with a stock exhaust as the car sounded and looked completely stock from the outside but gave quit a kick once you throttled in.
Here is my current part list:
Current Power Parts
New shortblock from Subaru
OEM Valves & Retainers
Custom CP 11:1 Pistons with crown coating & upgraded wrist pins
Custom Carillo H Rods
ACL rod bearings
ARP2000 Head studs
Modified oil pump
Kelford Valve Springs
ACT 6 puck sprung street clutch
DSS Axles
Other MISC Parts
KSport Coilovers
Zeitronix ECA-1
Innovate LC-2
P3 Gauge (likely to be replaced with home-made setup)
Enkei RPF01 18x9.5 +38
Retrofit Source HID retrofit
KOYO Radiator
Pending Parts on Order
JDL EL Turbo Kit
GTX3071 .63 AR
JDL 3” Overpipe
JDL 3” catless Front Pipe
JDL 3" single exit exhaust
Greddy SP Elite Muffler - Temporary
Spal fans (one thick one thin)
Custom fan shroud
Planned Parts List
Full blown fuel pump canister + Walbro 485
ID 1000cc injectors
OIL Cooler
Voodoo13 LCA
Frodo Pads
DBA Rotors
Undecided catch can
Long Term Parts List
Work CR Ultimate in WMB (unless I change my mind)
Front Splitter
“Mellow” rear diffuser
Vertex Skirts
Undecided Parts
Trunk Lip
??? Front Lip
Vented Catch Can Setup (I need to decide this asap)
I will be tuning the car my self. And already booked 20hrs of dyno time to dedicate to the car to make sure the tune is extremely well rounded in every scenario on every fuel mix.
Misc Pictures:
Old vs New axles:
Old Dyno:
I'll post up more pictures of the build once I catch up on some work. I have a bunch from the tear down & assembly of the new block.
My flickr - Canibeat
Local magazine scout
The Following 9 Users Say Thank You to nelsmar For This Useful Post:
alexand3r (04-24-2014), civicdrivr (01-05-2015), DustinS (05-26-2015), Lonewolf (04-03-2014), MJones_RB (06-17-2015), Pizzman (04-22-2014), SkAsphalt (03-23-2014), Sportsguy83 (03-24-2014), Tye300 (04-21-2014)
Old 03-23-2014, 09:59 PM   #2
nelsmar
Reserved
The Following User Says Thank You to nelsmar For This Useful Post:
Old 03-23-2014, 10:00 PM   #3
nelsmar
And as an update about my current build status... The engine is assembled and ready for install. However somehow I did not notice that my #2 exhaust cam was damaged. I am currently searching for a new one... Looks like I might just have to bite the bullet and over night one tomorrow.
Old 03-24-2014, 10:39 AM   #4
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
From Jaaaaaaaaapan?
The Following 4 Users Say Thank You to King Tut For This Useful Post:
Bach415 (03-24-2014), Lonewolf (04-03-2014), Mad1723 (04-11-2014), SkAsphalt (03-24-2014)
Old 03-24-2014, 10:41 AM   #5
nelsmar
From Jaaaaaaaaapan?
lol luckily they had one in the US. I just overnighted it, it will be here tomorrow at noon. =x
Old 03-24-2014, 10:54 AM   #6
nelsmar
Stupid Cam...
And some more pic's of assembly.
Stock rods that came in the short block. I am not quite sure what to do with these... It was cheaper for me to buy a shortblock than just the crank & block halves.
My new itty bitty turbo.
The Following 3 Users Say Thank You to nelsmar For This Useful Post:
jack43 (03-24-2014), SirBrass (03-24-2014), SkAsphalt (03-24-2014)
Old 03-24-2014, 02:18 PM   #7
xxscaxx
Drives: 2013 SWP BRZ
I may have missed it, but whos doing the motor build? Good luck man! Will be following along.
xxscaxx is offline   Reply With Quote
Old 03-24-2014, 02:59 PM   #8
nelsmar
Originally I was going to be doing the entire assembly. However due to me being INSANELY busy at work the last few weeks (I tapped 120+HRS in the last 7 days iirc) I haven't had time to assemble the block so I had my friend over at Goodspeed Peformance assemble the block for me.
xxscaxx (03-24-2014)
Old 03-24-2014, 03:04 PM   #9
Drift&Drag
TURBOLICIOUS
Drift&Drag's Avatar
Drives: a machine :]
Now that's a sweet pic!
Drift&Drag is offline   Reply With Quote
Old 03-24-2014, 03:08 PM   #10
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Call Harry if you need to overnight parts from JAPAN.
Congrats on your birthday!!
The Following User Says Thank You to Sportsguy83 For This Useful Post:
nelsmar (03-24-2014)
Old 03-24-2014, 03:14 PM   #11
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I keep seeing your desperate sounding posts for help on Facebook. I already offered my help if you decide you don't need someone local, haha.
Old 03-24-2014, 03:18 PM   #12
mfbmike
Drives: 2013 FRS, 2008 R32
You take awesome pictures.
In for awesome pictures.
mfbmike is offline   Reply With Quote
Old 03-25-2014, 03:47 PM   #13
AZFA20
Automotive Connoisseur
AZFA20's Avatar
Drives: too many cars
Just for future reference you could have PMed me to build it
LSx Powered 86/ASE Master Certified Automotive Technician
AZFA20 is offline   Reply With Quote
Old 03-25-2014, 04:45 PM   #14
nelsmar
We haven't even met! lol. Well other than a hello while I was drunk one afternoon. I wanted to do it 100% my self but life is just too damn busy -.-. At my current rate if I didn't have my friend assemble I wouldn't be installing until mid summer.
dyno, rebuild, turbo
Search this Thread:
Advanced Search
DIY - Brake Caliper Rebuild smbstyle DIY (Do-It-Yourself) Guides 13 03-20-2016 08:12 PM
Rebuild/install thread: Endless Big Brake Kit from WRX onto BRZ mav1178 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 38 04-09-2015 04:22 AM
My 1:10 Mini Me - Rebuild Finished! boredom.is.me Scion FR-S / Toyota 86 GT86 General Forum 99 03-02-2014 02:58 AM
rebuild works vs-xx 18x13.5 Jhon19lopez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 34 12-16-2013 04:13 PM
How often to rebuild coilovers or stock shocks? stockysnail Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 12-24-2012 01:54 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
