Drives: Panda FR-S
Oil Leak at Camshaft Timing Controler
Looks like the sealant at the assembly blew out under the exhuast camshaft timer and now my oil is leaking. Anyone know what the repair bill on this will be? They will probably need to take the engine apart and reseal. To comfort ya'll, I'm boosted at 71k miles on my car.
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
![]() 242whp/197ft-lb on Mustang Dyno (91 octane water) 284whp/223ft-lb on Mustang Dyno (E85) Delicious Tuning |
The SquadWhisperer
Drives: '13 Ultramarine FR-S (STX)
I've been putting off getting the dealer to look at mine in an attempt to find others with this issue. Mine is on the other side but looks exactly the same. Are you sure its not actually leaking at the timing cover/block mating surface? Perhaps the dirt on the timing cover is just missing on the "bottom" of the curves due to gravity as opposed to it being washed off by the oil?
I know the dealers typically remove the engine to do the timing cover, not sure about the sensor.
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion 2017 Bluenose Autosport Club Overall Rallycross Champion Powered by Great North Performance, Jani-King Canada, and OK Tire. |
Drives: frs
Check this TSB:
http://www.ft86club.com/forums/showp...&postcount=187 Y don't you just trade it in for something else? Or maybe for a new '15 if you like it that much.
Drives: old
You sure it isn't oil blown out of that breather filter?
Drives: None
@Cal3000 are you still driving it? That really sucks, I noticed leaking on my car on the opposite side of yours, and on only at 28k miles. 3k miles are with the avo kit.
Let me know if you get a quote please Sent from my iPad using Tapatalk |
Drives: ft86
mine did the same. dealer wouldn't fix it until it leaked where puddles will form.
Drives: None
Drives: car
Discovered oil running out from underneath my car while it was raining. Ran papertowel underneath cam plate and there was some burned oil there. Going to make a call to dealership and see what they'll do.
Drives: ft86
#11 | |
Drives: Panda FR-S
Planning to take it to a local tune shop. I told them the issue and they quotes me at $300 for the fix which I think is pretty cheap compared to what the dealer might charge.
#12 | |
Drives: None
#13 | |
Drives: None
Sent from my LG-D850 using Tapatalk |
#14 |
Drives: None
| Timing Cover Oil Leak | AllDayJonRay | Issues | Warranty | Recalls / TSB | 18 | 06-06-2016 03:12 AM |
| Timing Chain Cover Leak | alexand3r | Engine, Exhaust, Transmission | 17 | 09-29-2015 11:05 AM |
| oil leak at timing cover | choi0706 | Issues | Warranty | Recalls / TSB | 8 | 09-10-2014 06:25 PM |
| Different Camshaft Part numbers for 2014 model? | brn12345 | Engine, Exhaust, Transmission | 2 | 04-21-2014 11:51 AM |
| New TSB for camshaft sensor | whitefrs | Issues | Warranty | Recalls / TSB | 13 | 03-11-2014 02:54 PM |
