#71 |
Drives: Pavement MT GR86
You, if the car you're referring to is yours and not something you are helping build and tune for someone else.
600hp is a lot last time I checked.
GR86 MT premium
#72 | |
Yes this is actually for my personal vehicle. I simply don't want to invest in a part that has a cap close to where my car may end up being. The fun thing about turbo's is you can run them out of their efficiency range and make a little 'extra' power over what you are intending, and simply activate this via map switching a button, a knob, or however you want. I purchased a semi-properly sized turbo for my setup that could potentially push that far, and if i decide one day I want to push it further an upgrade is extremely easy to do. I'll eventually post a build thread. And personally I am not using a huge turbo, I just happen to have a fairly high compression engine with forged internals. Remember 350WTQ @ 8,200RPM is roughly 550WHP. So the basis of 600WHP is confusing, and not quite useful to someone like me. I just wondered if this had a TQ rating based off force, or if maybe it happened to be 600WHP based off the acceleration of the rotation or something like that so I could get an idea of what the limits were and if the carbon drive shaft was really required for my personal vehicle. I am planning on 300-375WTQ ballpark on a "high power" map.
When I grow up, I wanna be God. My flickr - Canibeat Local magazine scout Old Setup: Vortech Supercharged 360WHP/262WTQ @ 11.5psi My build thread - WTF happened to nelsmar's car thread |
#73 |
I'm curious as well however my vehicle will probably never see North of 300whp even after I'm bored with NA and grab a SC.
What I'm more curious about is how much and what type of noise will be added. Since I'm debating on selling my crank pulley since it whines (we'll see if I can hear it over the headers)
GR86 MT premium
#74 |
Automotive Connoisseur
Drives: too many cars
A rule of thumb on all my builds is to overbuild and under tune if you want something that will last a long time. However, if you're a one hit wonder type builder then this doesn't apply. If you're near the limits there is no sense in buying something that just barely covers your butt because instead it often just comes back to bite it instead. I can't count how many forum buddies my cars have outlasted as a result of this thinking. Unless you have endless funding then do whatever you want. Personally if you invest enough to build a 600hp 86 then why cheap out on a fairly critical component that puts that power where it belongs?
LSx Powered 86/ASE Master Certified Automotive Technician
| The Following User Says Thank You to AZFA20 For This Useful Post: | HI (04-13-2014) |
#75 | |
#76 |
Drives: 2014 Scion FR-S|Whiteout
My SHAFT arrived just now. I plan to play with my SHAFT and install it this weekend
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt |
| The Following 3 Users Say Thank You to *LongFella For This Useful Post: |
#77 |
Drives: 2013 MT Asphalt FRS
^^^ that shaft is one longfella
| The Following User Says Thank You to Carlitoz3 For This Useful Post: | *LongFella (03-06-2014) |
#78 |
^ LOL!
#79 |
Driveshaft Shop Carbon and Aluminium Lightweight Driveshafts - Video
I installed my SHAFT yesterday
![]() It's a noticeable improvement when revving the engine. I also installed a pulley kit by Raceseng, so that adds to the quickness too. It was a really easy installed. Had my car on four Jack stands and was able to get to everything. The four bolts at the rear end of the shaft where a PITA to get loose! I've noticed a very very slight shaking of my rear view mirror. Nothing crazing and you don't really feel anything, but you can see it when you look at the mirror. I'll try that 90 degree rout action thing and see if it goes away... If not, I'm not worried about it since it really isn't that noticeable. Maybe it's the Supercharger kit I installed too ![]() All in all, it's a great SHAFT and feels amazing!
| The Following 2 Users Say Thank You to *LongFella For This Useful Post: | 86-tundra (03-18-2014), FT-86 SpeedFactory (03-10-2014) |
#80 |
After a few days of driving around, it is definitely a noticeable difference compared to stock. My revs drop significantly quicker between shifts and the engines feels more agile.
For such an easy install and improvement in driving feel, it was worth every penny! Thanks @FT-86 Speed Factory
| The Following User Says Thank You to *LongFella For This Useful Post: | FT-86 SpeedFactory (03-14-2014) |
#81 |
We have the Carbon one on our race car with lightweight flywheel, lightweight pulleys and 4.67 final gear. The car revs insanely quick.
| The Following User Says Thank You to FT-86 SpeedFactory For This Useful Post: | *LongFella (03-14-2014) |
#82 | |
) With those components it really does wind up fast. I totally forgot you guys had the 4.67 in yours. Now I am bummed I didn't stay to go out on the track with you in CA.
#83 | |
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
SOLD THEM BOTH
Hers: 2007 987S Mine: 2012 991S That was fun, thanks Hachi ![]() |
#84 |
Drives: FRS
| DIY: Driveshaft Shop (DSS) Carbon Fibre Driveshaft | F1point4 | DIY (Do-It-Yourself) Guides | 67 | 04-17-2021 05:21 PM |
| Driveshaft Shop Carbon Fiber Shafts Explained | Driveshaft Shop | Engine, Exhaust, Transmission | 121 | 11-17-2017 11:57 AM |
| New The Driveshaft Shop Carbon Fiber 1-Piece Driveshaft | Evasive Motorsports | Engine, Exhaust, Transmission | 1 | 09-24-2013 02:27 PM |
| WTB: Driveshaft Shop (or lighter) driveshaft | Anthony | Want-To-Buy Requests | 8 | 08-27-2013 12:30 PM |
| Driveshaft Shop CF Driveshaft installed. | Hawaiian | Engine, Exhaust, Transmission | 5 | 08-13-2013 02:04 PM |
