Old 09-20-2013, 04:15 AM   #1
Evasive Motorsports
Evasive Motorsports's Avatar
Drives: 2012 FR-S and BR-Z
Send a message via AIM to Evasive Motorsports
New The Driveshaft Shop Carbon Fiber 1-Piece Driveshaft
The 1-piece driveshaft for the 2012 Scion FR-S / Subaru BRZ / Toyota GT86 is a complete 2.75" Carbon Fiber shaft that is approximately 1/2 the weight of the factory 2-piece driveshaft. The 1-piece carbon shaft features larger, replaceable u-joints and can handle about 800WHP. We had the tubing custom wound with a high modulus fiber to ensure the strength while making it small enough to clear everything under the car. All of the factory shields, plates and covers can be used without any alteration to the car at all. The ends are made from 6061-T6 aluminum and that shaft weighs a mere 12.2lbs. Not only will the car feel more responsive but it will also make a noticeable difference on the noise level in the car.
By removing the factory 2-piece shaft and installing a single shaft, the car will feel more responsive due to the lighter weight of the shaft and also the fact that the hanger bearing is not moving up and down during acceleration. Available for most popular motor/trans combinations, if you don’t see yours listed, custom shafts are also available.
Evasive Motorsports is offline
Old 09-24-2013, 02:27 PM   #2
Evasive Motorsports
We have these instock
DIY: Driveshaft Shop (DSS) Carbon Fibre Driveshaft F1point4 DIY (Do-It-Yourself) Guides 67 04-17-2021 05:21 PM
Driveshaft Shop Carbon Fiber Shafts Explained Driveshaft Shop Engine, Exhaust, Transmission 121 11-17-2017 11:57 AM
PST Carbon Fiber Driveshaft crank Engine, Exhaust, Transmission 18 10-19-2015 06:13 AM
WTB: Driveshaft Shop (or lighter) driveshaft Anthony Want-To-Buy Requests 8 08-27-2013 12:30 PM
Driveshaft Shop CF Driveshaft installed. Hawaiian Engine, Exhaust, Transmission 5 08-13-2013 02:04 PM
