Old 06-21-2013, 11:18 AM   #1
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
DIY: Driveshaft Shop (DSS) Carbon Fibre Driveshaft
Driveshaft Shop (DSS) Carbon Fibre Driveshaft DIY!
20130615-DriveshaftShop86-001 by VictorN07, on Flickr
Hey team 86. Today we have a new bit of kit in the labs, the Driveshaft Shop (DSS) Carbon Fibre Driveshaft. The purpose of replacing your OEM driveshaft with a lighter one made from aluminium and/ or carbon fibre is to reduce rotational mass and make power transfer from the gearbox to the differential more efficient. The net result is a more responsive car.
It is a single piece unit vs our dual section unit. Since the DSS kit doesn't have that pivot point like the OEM, then it can transfer energy more efficiently.
Unlike the OEM one, this carbon fibre driveshaft doesn't have a shaft collar. Normally having a collar is good in the event that your driveshaft falls out of the gearbox and catapults your car in the air. In this case, if there is failure in this driveshaft it will simply shatter/shred into many pieces.
The U joints are replacable and DSS claims this driveshaft can handle 800whp.
The ends are made from 6061-T6 aluminum. They've been in the business for a while making driveshafts for big power cars so I'll take their word this is serious business.
Is it worth it? We installed this in the Phastek Performance shop car so I'll @Chris@Phastek fill you guys in.
The goods
This is the end of the driveshaft that mates to the differential. It is a beefy joint.
20130615-DriveshaftShop86-002 by VictorN07, on Flickr
This end slots into the gearbox. There isn't a cup on this end like the OEM driveshaft but that's okay. This end is seals the gearbox so fluid and air cannot enter or escape. Inside this aluminium end is keyed so the output shaft of the gearbox can turn the driveshaft.
20130615-DriveshaftShop86-003 by VictorN07, on Flickr
The driveshaft is wrapped in this material. There is a large Driveshaft shop logo and phone number on the unit itself
20130615-DriveshaftShop86-004 by VictorN07, on Flickr
Weight
The DSS driveshaft is about 1/2 the weight of the OEM driveshaft. Big savings since its rotational mass.
20130615-DriveshaftShop86-005 by VictorN07, on Flickr
20130615-DriveshaftShop86-006 by VictorN07, on Flickr
20130615-DriveshaftShop86-007 by VictorN07, on Flickr
20130615-DriveshaftShop86-008 by VictorN07, on Flickr
DIY Lets go!
Some of these are just photos of @Chris@Phastek's car.
20130615-DriveshaftShop86-009 by VictorN07, on Flickr
20130615-DriveshaftShop86-010 by VictorN07, on Flickr
Here is the driveshaft inserted into the rear of the gearbox. The DSS shaft will not fill that silver cup when its installed.
20130615-DriveshaftShop86-011 by VictorN07, on Flickr
This is the driveshaft to differential connection. It is held together with 4 bolts
20130615-DriveshaftShop86-012 by VictorN07, on Flickr
Picture of the OEM Driveshaft collar mounted to the transmission tunnel
20130615-DriveshaftShop86-013 by VictorN07, on Flickr
20130615-DriveshaftShop86-014 by VictorN07, on Flickr
20130615-DriveshaftShop86-015 by VictorN07, on Flickr
Depending on the tools that you have you may have to put the car into gear and/or apply teh e-brake to keep the driveshaft from turning while you break loose the bolts
20130615-DriveshaftShop86-016 by VictorN07, on Flickr
20130615-DriveshaftShop86-017 by VictorN07, on Flickr
20130615-DriveshaftShop86-018 by VictorN07, on Flickr
20130615-DriveshaftShop86-019 by VictorN07, on Flickr
20130615-DriveshaftShop86-020 by VictorN07, on Flickr
20130615-DriveshaftShop86-021 by VictorN07, on Flickr
Finished!!!
Chris will get some more pictures of the finished product! I was occupied with other mods at the time and forgot to take finished photos.
F1point4 is offline   Reply With Quote
Old 06-21-2013, 11:30 AM   #2
PhastekSport
PhastekSport's Avatar
Send a message via AIM to PhastekSport Send a message via Yahoo to PhastekSport
Victor did the honors of adding post installation pictures. I had to upgrade my fog lights, so I put it on the lift again.
http://www.ft86club.com/forums/showp...0&postcount=13
DSS axles going in next!
Sent from my LG-E980 using Tapatalk 4 Beta
PhastekSport is offline   Reply With Quote
Old 06-21-2013, 11:56 AM   #3
charged86
charged86's Avatar
Wonder how fun this will be laying on the ground. Again superb DIY. By Mr. @F1point4
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 06-21-2013, 12:13 PM   #4
OrbitalEllipses
Drives: Attitude
Yeah, this seems easy, but I'm loathe to try this on the ground... approximately how much gearbox fluid drained out? I'm also a tad concerned that trying to not lose much fluid would result in my damaging the seals...
Old 06-21-2013, 12:17 PM   #5
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Thanks for another great write up! Any noticeable difference in driveline response after installing the DSS driveshaft?
Old 06-21-2013, 12:24 PM   #6
PhastekSport
Approximately nothing! Victor had the DSS driveshaft in hand as I removed the stock one. I am pretty sure not a single drop hit the floor.
Seems as if all slack has been taken out. There is a Houston event this weekend where I'll welcome some people to try it out and give feedback.
Old 06-21-2013, 12:39 PM   #7
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
I'd like to know as well.
G_Ride is offline   Reply With Quote
Old 06-21-2013, 01:19 PM   #8
swift996
swift996's Avatar
Do you have any pics of both ends of the carbon shaft mounted?
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 06-21-2013, 01:20 PM   #9
F1point4
Photo Specialist
F1point4's Avatar
Next time Chris's car is on the lift he'll get some, or i'll get some if I'm with him.
Sorry I just forgot.
Old 06-21-2013, 01:29 PM   #10
swift996
swift996's Avatar
I'd appreciate it as I plan to do the same in my driveway. Would be helpful to make sure I got everything on there right (seems pretty straight forward). As always, thanks for sharing the detail.
Old 06-21-2013, 09:52 PM   #11
PhastekSport
I have to work on a couple of things tomorrow morning. I'll probably get it on the lift again.
Old 06-21-2013, 09:56 PM   #12
OrbitalEllipses
Drives: Attitude
This is the type of thing that is entirely possible on your driveway, but probably better with two people... let me know what you plan on doing and we can have a double date.
Old 06-23-2013, 12:43 AM   #13
F1point4
Photo Specialist
F1point4's Avatar
More Pictures
You ask we listen (sometimes)!!!
20130622-DSS-CFDriveshaft-After-046 by VictorN07, on Flickr
20130622-DSS-CFDriveshaft-After-042 by VictorN07, on Flickr
20130622-DSS-CFDriveshaft-After-039 by VictorN07, on Flickr
20130622-DSS-CFDriveshaft-After-064 by VictorN07, on Flickr
Closeups
20130622-DSS-CFDriveshaft-After-003 by VictorN07, on Flickr
20130622-DSS-CFDriveshaft-After-028 by VictorN07, on Flickr
20130622-DSS-CFDriveshaft-After-024 by VictorN07, on Flickr
20130622-DSS-CFDriveshaft-After-010 by VictorN07, on Flickr
20130622-DSS-CFDriveshaft-After-005 by VictorN07, on Flickr
Old 06-23-2013, 02:43 AM   #14
FRSfan111
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
Definitely on my list. Lol this, brake cooling, oil cooling and final drive.
In for results!
FRSfan111 is offline   Reply With Quote
diy, driveshaft, driveshaft shop, dss
Driveshaft Shop Carbon Fiber Shafts Explained Driveshaft Shop Engine, Exhaust, Transmission 121 11-17-2017 11:57 AM
Driveshaft Shop Axles & Upgrades for Scion FR-S!! MVP Motorsports RobertatMVP Transmission and Driveline 39 07-11-2014 01:48 PM
Driveshaft on a DD FRS Bullnettles Engine, Exhaust, Transmission 31 10-06-2013 01:22 PM
The Driveshaft Shop Custom Axles and Shafts Sportsguy83 Engine, Exhaust, Transmission 26 01-11-2013 04:55 PM
Automatic Carbon Fiber Driveshaft? Yes! RallySport Direct Engine, Exhaust, Transmission 13 12-15-2012 12:40 AM
