Old 03-02-2014, 07:46 PM   #351
Kronos
Kronos's Avatar
Drives: Asphalt FR-S MT
Thanks for the quick response! You probably know more than I do
Pretty sure it's mostly if not all e85. I've been filling up with e85 ever since I switched over. Probably 2 tanks worth.
Although this makes me wonder my e content. This is the closest station by me that has e85
Kronos is offline   Reply With Quote
Old 03-02-2014, 08:00 PM   #352
bfrank1972
Drives: 2013 FR-S Argento
Originally Posted by shiv@vishnu View Post
As long as you are running more than ~e60, just drive the car. If it's lean now it's only because it needs to relearn from running too rich before. This doesn't take very long and you have more than enough octane to not worry about running lean during this process.
@shiv@vishnu, is the E85 EL OTS tune good down to E60 because there's a limit to how much timing you can advance or is it a safety margin. In other words - if we're confident our ethanol is in the higher range is there room to produce more power in your opinion? thanks!
Old 03-02-2014, 08:15 PM   #353
gonzo
Drives: frs
Attachment 68984
http://www.ebay.com/itm/Deluxe-Fuel-...item19e1f4f33e
These aren't very precise because they're lacking fine markings between e20 and e85, but you could always get it to test. Although I don't know how much it'll help since the blend will likely change every time you visit the station. And what will you do if the blend is low in ethanol? Get gas instead? I wouldn't worry about it too much. Just check your logs every time you fill up to make sure something weird isn't happening.
gonzo is offline   Reply With Quote
Old 03-06-2014, 09:14 PM   #354
HSayaovong
HSayaovong's Avatar
Drives: blk;2dr;rwd;fun
Hey guys, I've been on the e85 tune for roughly 3 tanks now but something strange happened this morning, when I started up the car this morning the check engine light came on.. I'm not sure if it was the best idea but I just cleared it with the OFT. Does the e85 tune throw check engine light for anyone else?
Life is like taking a dump, sometimes it's easy and other times its hard. But it always stinks
HSayaovong is offline   Reply With Quote
Old 03-06-2014, 09:39 PM   #355
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
Originally Posted by gonzo View Post
I'm on e85 that's a little mixed with gas I would guess around e70 (first time I filled with e85 i had 3 gallons of 91 in my tank, second time I filled with e85 once I got to half empty on that first tank)
My AFR is too high. Should I rereflash now that I'm running a higher ethanol content? I think my first tank was about e60. With that tank, my afr was in the low 12s. Now that my tank has a higher ethanol mixture the AFR is in the mid 13s.
http://datazap.me/u/gonzo/gonzo-0302
I haven't taken it past 6000 rpm because I was worried how lean it is
I have the stock airbox with a drop in filter, nameless catted front pipe, and nameless axle back
Why not just the full tank right off the bat?
Carlitoz3 is offline   Reply With Quote
Old 03-06-2014, 09:41 PM   #356
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Take it easy for 50 miles or so. The computer should correct.
Old 03-07-2014, 12:55 PM   #357
gonzo
Drives: frs
I think you misunderstood what I was trying to explain.
The first time I filled with e85 I was right before the gas light turns on (2-3 gallons left). I was hoping the light would turn on by the time I would get to the station but it didn't.
The next time I filled was when that first tank got to half empty. Both times I filled till the tank was full.
I don't do much driving, so I didn't want to wait till my tank was empty (although in hindsight I should have). I'm very impatient
Old 03-07-2014, 12:57 PM   #358
gonzo
Drives: frs
Did you check the code? Always check the code before clearing it!
Old 03-07-2014, 12:58 PM   #359
gonzo
Drives: frs
I'm sure there is room to produce more power on the tune. But is that possible without a dyno?
Old 03-07-2014, 01:30 PM   #360
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
Originally Posted by tonystewart View Post
Hence my need for a Helmholtz Resonator on my Nameless Catted Front Pipe.
Tamed that particular sound
Are you sure about that? I have the same op fp from nameless and i still hear that valve flutter. Sound comes from the engine not the exhaust
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
Old 03-07-2014, 02:23 PM   #361
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Yes sir, it tamed it down, it didn't eliminate it. Reducing the noise was our target.
I'm sorry if this not helpful
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 03-07-2014, 07:03 PM   #362
Pistol
Drives: 86
hmm
im on e85 stage 2 tune,1.55
maybe 5th- 6th tank of e85 and its hardly what i call cold in the morning maybe 14 celsius
however took me seven attempts to get car started
winter isnt even close yet, and dont really want to add fuel to change mixture
@shiv@vishnu is there a solution for this
here is log from third tank
http://datazap.me/u/pistol/e85-3rd-t...der-1-2-3-pull
Pistol is offline   Reply With Quote
Old 03-12-2014, 08:32 PM   #363
Drofnum
Drives: CBS Subaru BRZ
Anyone wanna take a look at my log and see how it looks? Nothing looks to out of place to me except maybe knock correction? This is after about 50 miles on the e85 tune so its probably still learning a bit.
http://www.datazap.me/u/drofnum/0312...1-8-9-10-11-12
Drofnum is offline   Reply With Quote
Old 03-12-2014, 08:44 PM   #364
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
You're still running rich with several % of negative fuel trim. That tells me that you still had quite a bit of gasoline in your tank when you added e85?
Shiv@Openflash is offline   Reply With Quote
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 05:23 PM
Is Openflash tablet detectable? Boofneenee Software Tuning 25 05-02-2014 10:03 PM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 08:45 PM
WTB Openflash Tablet Vlady Want-To-Buy Requests 0 10-25-2013 12:10 AM
