Old 11-18-2013, 10:01 PM   #1
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Smile OpenFlash Tablet E85 (and gasoline) Maps now available
Hi guys,
New FREE maps (v1.34) can now be downloaded from our website. These include our new E85 maps.
As per the Read Me File (please read carefully):
11/18/13
v1.34beta Changes:
-Revised VVT Exhaust mapping for more power above 7200rpm in all tuned ROMs
-Implemented Soft Rev limiter feature in all tuned ROMs
-Revised Idle Target mapping for lower engine speed during cold start (by popular request)
-Added E85 maps for US Market ROMS (C and D series). This map is intended for cars running straight E85 fuel. As with all of our maps, this is intended for cars equipped with stock airbox housing. Aftermarket filter and modified duct is recommended for maximum power. Please note that this map was calibrated on a car with aftermarket carless header. It has not yet been tested on vehicles with stock header.
-Updated XDF files for all ROMs. Non-US XDF files still aren't complete but they are slightly more developed than last release.
Other info:
Currently, we recommend only running straight E85 fuel with out E85 map. This means running your gasoline level low (until low fuel light comes on) and then filling up with E85. And from that point onwards, running straight E85 with each additional fill up. During the next couple of weeks, we will be doing testing on various ethanol % contents to determine how flexible the tune. Until then, we recommend sticking with straight E85 if you choose to run the E85 tune. When you want to go back to running gasoline, just run the tank of E85 low and then fill up with gasoline. But don't forget to flash your ECU with the gasoline tune map or else your tune will be much too aggressive!
Please note that we have revised cold cranking fuel enrichment so that the engine starts up first try in the morning when running E85. But our cold mornings here in CA haven't been that cold (45F). As the winter drags on, and temps drop, we will probably revise these tables a bit. So if you live in a winter wonderland, don't be surprised if you need to crank the engine a couple of times before it finally starts first thing the morning.
Now that on-screen data viewing is functional, here's some more info on what you should see when running the E85 tune:
- At full throttle, AFR should be in the 12.5-12.8 range
- At full throttle, long-term fuel trims should be well within +/- 4%. Immediately after the flash, it will be 0%. But then it will slowly adapt over time. As long as you are running the stock airbox, it shouldn't move around much. If you are an aftermarket intake and see big fuel trims, this map may not be suitable for you.
Lastly, if anyone has any issues with the E85 map, please email me directly at shiv@vishnutuning.com.
Cheers,
Shiv
Old 11-18-2013, 10:29 PM   #2
Malt
Drives: 2015 WRX
So excited. Just added 2 gallons of fuel this afternoon so I need to go find a reason to burn off those to fill up with E85! Thanks shiv, I don't think I've been so excited about a mod in quite a while.
Malt is offline   Reply With Quote
Old 11-18-2013, 10:31 PM   #3
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
This is exciting news. What sort of issues (running rich, running lean, retarded timing) do you think is going to arise with a stock header and the tune?
Luckrider is offline   Reply With Quote
Old 11-18-2013, 10:33 PM   #4
Shiv@Openflash
Drives: 2013 FRS
Mostly likely nothing. But without testing it myself, I can't officially recommend it to others.
Old 11-18-2013, 10:35 PM   #5
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
nvm went thru tunerpro comparison. looks good
IG-Joey_Soul
Old 11-18-2013, 10:39 PM   #6
1Cor10:23
1Cor10:23's Avatar
Is there a stage 1 premium gas map included in 1.34? Thanks! So glad I bought into this platform, loving the constant activity and development!
Edit: nvm read description on website
Sent from my SGH-I317M using Tapatalk
Old 11-18-2013, 10:47 PM   #7
Malt
Drives: 2015 WRX
I'm glad I went with this tuning solution as well. I can remember fondly reading about Shiv's tuned EVO that was featured back in the day in a magazine (can't remember which one now) but it smoked several cars that cost multiple times. I knew then that when I got back into the sports car world I was going to get a tune from him. Imagine my surprise when I found out he was behind something as awesome as open source tuning.
Old 11-18-2013, 11:06 PM   #8
1086
1086's Avatar
Drives: UM86 - 6MT
@shiv@vishnu - At a minimum, do I only need this e85 tune to run E85 on my car with success? or do I need more than just the tune to run E85?
1086 is offline   Reply With Quote
Old 11-19-2013, 12:12 AM   #9
yuicebox
Drives: Asphalt FRS
@shiv@vishnu
So there's no Stage 1 E85 map, correct?
Catless headers are required to safely run this tune?
yuicebox is offline   Reply With Quote
Old 11-19-2013, 01:20 AM   #10
vynervt
Drives: GT-86
@shiv@vishnu
waiting for international XDF.... K series??
vynervt is offline   Reply With Quote
Old 11-19-2013, 04:57 AM   #11
Maverick22
Maverick22's Avatar
Drives: 2013 Rocketbunny GT86
This is exciting Shiv! good work! I am still waiting for FI support Also Bravo on Data logging!
Maverick22 is offline   Reply With Quote
Old 11-19-2013, 09:39 AM   #12
bfrank1972
Drives: 2013 FR-S Argento
Great news guys - if you have E85 convenient to you it's a whole different world. I'm pretty surprised the E85 maps are so tolerant of fluctuations in ethanol conent - I guess with a NA motor the benefits of full E85 are overkill? It would be good to define the minimum ethanol content necessary for this map, as well as how the long term trims adapt.
bfrank1972 is offline   Reply With Quote
Old 11-19-2013, 10:41 AM   #13
overlookedx
overlookedx's Avatar
Drives: 2015 WRB Limited
Too bad I literally just filled up last night, didn't realize this would be released so early in the week. But I'm definitely excited to try it out. Luckily I only go through a tank in about 2 days or so.
Superfast Jellyfish
overlookedx is offline   Reply With Quote
Old 11-19-2013, 10:47 AM   #14
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
I've got E85 *relatively* close. I'll try it out soon. Just filled up yesterday.
SloS14 is offline   Reply With Quote
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 05:23 PM
Is Openflash tablet detectable? Boofneenee Software Tuning 25 05-02-2014 10:03 PM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 08:45 PM
WTB Openflash Tablet Vlady Want-To-Buy Requests 0 10-25-2013 12:10 AM
