#351 |
Drives: Asphalt FR-S MT
Thanks for the quick response! You probably know more than I do
![]() Pretty sure it's mostly if not all e85. I've been filling up with e85 ever since I switched over. Probably 2 tanks worth. Although this makes me wonder my e content. This is the closest station by me that has e85 |
#352 | |
Drives: 2013 FR-S Argento
#353 | |
Drives: frs
These aren't very precise because they're lacking fine markings between e20 and e85, but you could always get it to test. Although I don't know how much it'll help since the blend will likely change every time you visit the station. And what will you do if the blend is low in ethanol? Get gas instead? I wouldn't worry about it too much. Just check your logs every time you fill up to make sure something weird isn't happening. |
#354 |
Drives: blk;2dr;rwd;fun
Hey guys, I've been on the e85 tune for roughly 3 tanks now but something strange happened this morning, when I started up the car this morning the check engine light came on.. I'm not sure if it was the best idea but I just cleared it with the OFT. Does the e85 tune throw check engine light for anyone else?
Life is like taking a dump, sometimes it's easy and other times its hard. But it always stinks
#355 | |
Drives: 2013 MT Asphalt FRS
#356 |
Dismember
Drives: 2013 Red Scion FR-S
Take it easy for 50 miles or so. The computer should correct.
#357 |
Drives: frs
I think you misunderstood what I was trying to explain.
The first time I filled with e85 I was right before the gas light turns on (2-3 gallons left). I was hoping the light would turn on by the time I would get to the station but it didn't. The next time I filled was when that first tank got to half empty. Both times I filled till the tank was full. I don't do much driving, so I didn't want to wait till my tank was empty (although in hindsight I should have). I'm very impatient
| The Following User Says Thank You to gonzo For This Useful Post: | Carlitoz3 (03-07-2014) |
#358 | |
Drives: frs
Did you check the code? Always check the code before clearing it! |
#359 | |
Drives: frs
#360 |
Go-Kart Enthusiast
Drives: Toyota Scion FRS
Are you sure about that? I have the same op fp from nameless and i still hear that valve flutter. Sound comes from the engine not the exhaust
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels |
#361 |
Drives: 2013 Scion FR-S Raven
Yes sir, it tamed it down, it didn't eliminate it. Reducing the noise was our target.
I'm sorry if this not helpful
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
#362 |
Drives: 86
hmm
im on e85 stage 2 tune,1.55 maybe 5th- 6th tank of e85 and its hardly what i call cold in the morning maybe 14 celsius however took me seven attempts to get car started winter isnt even close yet, and dont really want to add fuel to change mixture @shiv@vishnu is there a solution for this here is log from third tank http://datazap.me/u/pistol/e85-3rd-t...der-1-2-3-pull |
#363 |
Drives: CBS Subaru BRZ
Anyone wanna take a look at my log and see how it looks? Nothing looks to out of place to me except maybe knock correction? This is after about 50 miles on the e85 tune so its probably still learning a bit.
http://www.datazap.me/u/drofnum/0312...1-8-9-10-11-12 |
#364 | |
Drives: 2013 FRS
| OpenFlash Tablet | Rombinhood@OpenFlash | Software Tuning | 1838 | 07-29-2023 06:35 PM |
| Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download | Shiv@Openflash | Software Tuning | 354 | 02-08-2015 05:23 PM |
| Is Openflash tablet detectable? | Boofneenee | Software Tuning | 25 | 05-02-2014 10:03 PM |
| OpenFlash Tablet Stage 1 v1.2 maps available for download | Shiv@Openflash | Software Tuning | 31 | 10-31-2013 08:45 PM |
| WTB Openflash Tablet | Vlady | Want-To-Buy Requests | 0 | 10-25-2013 12:10 AM |
