Old 01-03-2014, 10:06 AM   #1
Jackal84
Jackal84's Avatar
Drives: Toyota GT86
Unhappy Rattle noise over 65mph (100kmh) on highway only
Hello to all!
Since October i have this very very cranky noise from the left side of my GT86...
This weekend I traveled over 1,000 km on the highway, my head was going to explode...
[ame="https://www.youtube.com/watch?v=STg76qmb8wM"]Toyota GT86 Rattle Noise over 100kmh - YouTube[/ame]
The noise come out over 65mph (over 100kmh) and increases exponentially with the increase of speed...
I removed the rear seat, side panels near the rear speaker and the lining of the trunk, but nothing, the noise is even stronger ...
the toyota dealer obviously does not know what it might be and how to fix ...
any ideas?
thanks!!
Jackal84 is offline   Reply With Quote
Old 01-03-2014, 10:22 AM   #2
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
@Jackal84 it could be this
http://www.ft86club.com/forums/showthread.php?t=42065
Or if that doesn't fix it then this
http://www.ft86club.com/forums/attac...1&d=1352827748
Has also been the rear seat pins for some that hold it in place at the top when you return them to the upright position after having them folded down. Make sure they are locked back in place by giving them a good shove. Some stuff on this here http://www.ft86club.com/forums/showt...ear+seat+noise
nzer is offline   Reply With Quote
Old 01-03-2014, 11:35 AM   #3
Jackal84
Jackal84's Avatar
Drives: Toyota GT86
Hello nzer!
Thanks for the answer!
I've tried all of these solutions some time ago (for other noises actually) but none has improved the thing
Old 01-03-2014, 03:03 PM   #4
nzer
nzer's Avatar
Ok @Jackal84 I have one more suggestion.
I had a noise that my dealer couldn't find after having my car for two weeks.
This is what they finally did. They took it to a body shop that had electronic "listening" equipment. It pinpointed the direction the noise was coming from and they then fixed it for me.
Try some body shops and see if one near you has this equipment.
I assume you have had someone drive your car while you're in the back so the electronics may be the only answer. Personally I couldn't be driven while with a torch in the trunk but others have - too dangerous and claustrophobic for me.
Old 01-03-2014, 09:00 PM   #5
roddy
roddy's Avatar
Drives: '13 Ultramarine
What do you mean by cranky? Is it a rattle/tapping sound? If so, does it change or become more noticeable in turbulent air (like a cross wind or when passing a large truck)?
Old 01-03-2014, 09:48 PM   #6
Hmmmm.........from your video, I don't hear anything other than road noise ..... ??
Can you describe the sound more specifically .. ??
Old 01-04-2014, 05:25 AM   #7
Jackal84
Jackal84's Avatar
Drives: Toyota GT86
Well, yesterday my situation was this...
I drove my car while my girlfriend try to listen/look where the noise come, it seems from the back, near the wheel...
It's like a rattle, like plastic on metal or metal on metal, if you go fast olver 80/90mph the noise in very loud, also depends on the type of asphalt.
The video was taken with an iphone5 and the car was on strandard exhaust (now i have a milltek, but the noise feels the same.
increases the volume you can clearly hear it, from 0.15, 0.27 and so on..
Today here in Italy is raining, so i can't take a serious video with my GoPro.. i will do that as soon i can.
Old 01-04-2014, 07:12 AM   #8
roddy
roddy's Avatar
@Jackal84 It really seems like it could be the rear fender liners. Mine were making a similar noise, and it drove me nuts until I found it. Go to your local hardware store and pick up a handful of 5/16" (8MM) and 3/8" (10MM) neoprene (rubber) bolt washers. IIRC, you'll need about 10 of the 5/16" and 3 or 4 3/8" per side. Jack up your car and pull the wheel off on the side that is making the noise. There is a plastic liner inside the wheel well that is held in with plastic push pins. Pop these pins out one at a time, and slide one of the rubber washers over the pin, and put the pin back in. It may take a bit of effort to make the pin "lock" back in place. It should be pretty obvious which ones will need the larger washer (I think it is the ones that also hold the little flap in front of the rear wheel). If this is your problem, these washers will take up the slack and keep the fender liner from moving around. Hope this helps.
Edit: I just listened to your video, and I am 99% sure this is your problem. That sound jumped right out at me...made me mumble grrr under my breath.
The Following 2 Users Say Thank You to roddy For This Useful Post:
Jackal84 (01-04-2014), nzer (01-04-2014)
Old 01-04-2014, 07:29 AM   #9
Jackal84
Jackal84's Avatar
Drives: Toyota GT86
Hello Roddy!!
This seems to be a good indication!!
So could be the rear fender plastic liner that over 65mhp begin to rattle...
Vedo di fare questa cosa il prima possibile!
Thanks!!!!!!!
Old 01-04-2014, 07:32 AM   #10
Jackal84
Jackal84's Avatar
Drives: Toyota GT86
@Jackal84
I hope you're really right! If I work out so I owe you one!
The noise is really annoying on the highway, this weekend I have done over 1100km of road and my head was exploding ...
Old 01-04-2014, 07:45 AM   #11
roddy
roddy's Avatar
It sounds like mine did. I would begin to notice it around 60 MPH, and it would get louder and more frequent as speed increased. Windy days and passing large trucks would also make it worse.
The Following User Says Thank You to roddy For This Useful Post:
Old 01-04-2014, 03:07 PM   #12
Jackal84
Jackal84's Avatar
Drives: Toyota GT86
Exaclty what happen to me, so i think/hope you have hit the point.
Tomorrow i will buy the washers and do the job... fingers crossed..
in the meantime, thank you again
Old 01-04-2014, 06:33 PM   #13
roddy
roddy's Avatar
No problem. I hope that fixes it for you. Let me know how it works out.
Old 01-05-2014, 03:53 PM   #14
Jackal84
Jackal84's Avatar
Drives: Toyota GT86
Hello!
Just done, tomorrow i will try on the highway...
Borla Header Rattle Noise tonytduc Issues | Warranty | Recalls / TSB 40 05-09-2014 01:28 PM
Huge noise after hitting a big bump on the highway! Help? Monstermotor BRZ First-Gen (2012+) — General Topics 10 08-20-2013 04:29 PM
Rear rattle/clunky noise Hawk77FT Issues | Warranty | Recalls / TSB 8 08-18-2013 06:59 PM
Very annoying rattle/noise in the back of my BRZ. Any help? MrGamer BRZ First-Gen (2012+) — General Topics 6 08-02-2013 09:32 AM
Wind/road noise at highway speeds? Kieranz BRZ First-Gen (2012+) — General Topics 20 06-13-2013 10:11 AM
