Old 08-18-2013, 08:26 AM   #1
Hawk77FT
Drives: GTS 86
Rear rattle/clunky noise
Ok, so recently I went for couple of spirited driving on some nice twisty roads. After say 15 minutes of driving I started to hear a strong clunky/rattle noise coming from the right hand side of the vehicle. It was very noticeable when I was taking the left corners (which were putting some pressure on the right hand side). I stopped the car for 10 minutes, inspected it but nothing.
Continued driving but after say another 5 minutes the noise came back. It just went away when I got onto the motorway.
On the second drive, I heard the same but only after I give it 10 minutes of twisties, otherwise there is no noise when on motorway/highway or I don't drive to the limits.
Does anyone know where that noise could come from? I checked all the rear sub-frame bolts but they all seem to be tight. Don't know why really!
Hawk77FT is offline   Reply With Quote
Old 08-18-2013, 08:49 AM   #2
campy
No rice, no life
campy's Avatar
Drives: 2013 Asphalt FR-S
Rear deck rattle?
http://www.ft86club.com/forums/showthread.php?t=42065
campy is offline   Reply With Quote
Old 08-18-2013, 09:24 AM   #3
Hawk77FT
Drives: GTS 86
Originally Posted by campy View Post
No, not at all. It sound like it's coming from the rear suspension or something. Sounds more like something's loose.
Old 08-18-2013, 09:37 AM   #4
campy
No rice, no life
campy's Avatar
Might be a bad shock absorber. Does the car seem to bounce a lot in corners?
Old 08-18-2013, 10:35 AM   #5
Argento_FR-S
Drives: Scion FR-S
Check your sound generator tube. If you look at where it is bolted to the intake manifold you will probably notice a worn spot on it. I have found that mine is VERY loose. I can just barely tap on mine and hear it hitting and making one of the many rattles I've started to hear. This sound worried me most though because it almost sounds like a bad rod knock that the old EJ motors were so famous for.
Argento_FR-S is offline   Reply With Quote
Old 08-18-2013, 04:19 PM   #6
Hawk77FT
Drives: GTS 86
Coming from the rear not front of the car.
Sent from my HTC One X using Tapatalk 2
Old 08-18-2013, 04:22 PM   #7
Hawk77FT
Drives: GTS 86
To some degree yes, I think that might be it. I will check with Toyota again.
But why after 10-15 minutes of abuse?
Old 08-18-2013, 04:24 PM   #8
Zgrinch
Zgrinch's Avatar
Drives: 2013 Limited DGM BRZ
Passenger side rear fender well area?
I have a rattle there and can't figure our the cause.
BRZGrincherhood
Zgrinch is offline   Reply With Quote
Old 08-18-2013, 06:59 PM   #9
Hawk77FT
Drives: GTS 86
Yeah, that is it! In my case is driver side (RHD car ) but yes...it sounds like somethings loose and it goes away if I let it sit for 10-15 minutes. I thought it might be the exhaust, checked it and nothing. Sometimes if i go over bumps it feels like the shock absorber is loose or something.
I will go to see the stealer sometimes over the next few days and let you know.
Borla Header Rattle Noise tonytduc Issues | Warranty | Recalls / TSB 40 05-09-2014 01:28 PM
Engine pinging (rattle noise) under acceleration sho AUSTRALIA 95 08-10-2013 05:52 PM
Very annoying rattle/noise in the back of my BRZ. Any help? MrGamer BRZ First-Gen (2012+) — General Topics 6 08-02-2013 09:32 AM
Rear deck rattle - fix it in 30s nzer AUSTRALIA 0 07-25-2013 04:09 PM
Rattle in rear left of car - Need some help! eleu2166 AUSTRALIA 4 12-01-2012 09:51 AM
