Northwest AK, ID, OR, WA
Old 08-19-2015, 09:52 PM   #1
Llilith
Witchy one
Llilith's Avatar
Drives: 2015 BRZ Ltd, Dark Grey Metallic
Thinking about lowering and camber adjustment, recommended shops in PDX?
So I'm thinking about having the car lowered a bit and getting the camber adjusted. Does anyone know a good shop in the PDX area?
Also - does anyone have any thoughts on doing this with the stock wheels and tires? I want to get that tougher stance, but I don't know much about how to get it. Spacers, camber adjustment and lowering right?
Is there really no factory adjustment for the rear camber on the BRZ?
Unless it's just a shame to do that with the stock wheels and tires. I wasn't going to buy new tires until they wear out, but I'd like to make what I have now look better.
Finally, does lowering the car void the warranty?
Thanks!
Llilith is offline   Reply With Quote
Old 08-19-2015, 10:46 PM   #2
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
You'll need springs or coilovers first, @DarrenDriven can help with that
As for camber there is no factory adjustment at all, you'll need bolts (or coilovers) up front and a lower control arm (simple solution) in the rear. I'll let other folks chime in on the visual aspects.
Lowering the car can lead to the dealer denying warranty coverage on axles, but that is because lowering puts extra stress on the CV joints.
Decay107 is offline   Reply With Quote
The Following User Says Thank You to Decay107 For This Useful Post:
Llilith (08-19-2015)
Old 08-20-2015, 12:37 AM   #3
Chen
Regional Moderator
Chen's Avatar
Drives: 00-AP1 20-A90 06-Z33 07-FA5 93-NA1
Seen slammed cars on stock wheels. 2 guys I can think of right now are pretty low. But aren't on the forums. (Dillion and spencer)
Chen is offline   Reply With Quote
Old 09-08-2015, 11:35 AM   #4
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Yesterday we installed some Stance Super Sport coilovers on @kevintran's 86. Pretty low on stock wheels...
Old 09-08-2015, 11:36 AM   #5
DarrenDriven
NW Region Moderator
Here he was back in May when he had his BC Coilovers dropped to max, with one of the collars removed to get even lower. This was ridiculous!
Recommended Shops (Southeast) Sportsguy83 Southeast 96 12-13-2022 02:34 PM
Recommended MD body shops? huyawns Cosmetic Modification (Interior/Exterior/Lighting) 1 03-26-2014 07:11 PM
camber adjustment SMOKETREES Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 05-26-2013 04:39 PM
regarding camber adjustment aruxe Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 05-10-2013 01:02 AM
KW V3 camber adjustment olorin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 01-28-2013 04:46 PM
