Lowered Lifestyle
Drives: Scion Fr-S
camber adjustment
How much would 1°-1.5° of camber affect the life of the tire. Would there be obvious tire wear on the side walls? Thx for your input :-)
Old School Status
Drives: .
depending on the width, air pressure and toe will have different results.
i've had -3 to -5 camber on my previous daily driven bB on 15x8 195/50 32psi and the -3 lasted for 8-11 months. -5 for 5months. proper toe correction will minimize wear.
Lowered Lifestyle
Drives: Scion Fr-S
Hsvent changed toe and probably won't cause I know changing toe can really mess with tire wear unevenly so that'll stay stock. I'm running about 35 psi in tires and my wheel size is, 18x8.75
Drives: 14' Monogram FRS, ulramarine, white
It also depends on the compound of the tire as well
whether it be low and slow, fast and loud, or riding on rails, make it unique and make it your own.
#5 | |
i'm sorry, what?
Drives: Canada
so if you're doing this yourself don't assume that you can just crank your camber bolts/plates and stroll along.
Drives: for the sake of driving
'13 Argento FR-S
Lap time enthusiast
Drives: Asphalt '13 FR-S 6MT
Toe will affect wear much more than camber.
| BRZ front camber adjustment confirmed | sparks | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 21 | 03-28-2013 10:17 PM |
| KW V3 camber adjustment | olorin | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 01-28-2013 04:46 PM |
| Rear camber adjustment options? | zooki | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 24 | 09-12-2012 10:46 AM |
