Old 07-10-2015, 02:37 PM   #1
JG
JG's Avatar
Drives: Whiteout FRS
Poor Overpipe Clearance
Current'y i'm running Openflash Header, Invidia Over pipe, Invidia Front pipe, Invidia straight pipe, Invidia N1 tips. My Over pipe seems to have horrible clearance as it is knocking against the metal beneath it.
My question is, does anyone have a good overpipe they would recommend that has good clearance?
Also maybe the front pipe doesn't curve up enough?
TY in advance
JG is offline   Reply With Quote
Old 07-10-2015, 03:24 PM   #2
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
When I had a Perrin OP, I never had an issue.
Freeman is offline   Reply With Quote
Old 07-10-2015, 03:49 PM   #3
JG
JG's Avatar
Do you remember about how much clearance it has? Mine only has about a quarter of an inch. Also did you switch?
Old 07-10-2015, 03:51 PM   #4
RobertPaulson
Hisnamewasrobertpaulson
RobertPaulson's Avatar
Drives: 2017 Golf R
i also have no issues with my perrin, but i also know plenty of people running the invidia op without any issues. maybe you just need to loosen everything up and re-set and re-tighten in a better place where it won't hit the sub-frame.
This is your life and it's ending one minute at a time.
RobertPaulson is offline   Reply With Quote
Old 07-10-2015, 03:52 PM   #5
Freeman
Freeman's Avatar
I swapped to a 3 inch OP and front pipe.
I don't remember the clearance amount but it never hit anything.
Old 07-10-2015, 04:04 PM   #6
JG
JG's Avatar
I've tried that. I can't tell you the amount of time i was under there and tried moving everything. I ended up wrapping the overpipe so it didn't have that nasty metal on metal sound. I'll look into Perrin then.
Old 07-10-2015, 04:39 PM   #7
RobertPaulson
Drives: 2017 Golf R
if the perrin give you the same problem i'd look into the header as the culprit.
Old 07-10-2015, 04:45 PM   #8
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
I've had no issues with my Motive op paired with either Stock, Nameless, or Tomei headers.
Decay107 is offline   Reply With Quote
Old 07-10-2015, 06:05 PM   #9
JG
JG's Avatar
This was happening before the headers were installed.
Old 07-11-2015, 03:48 AM   #10
Donbrz
Drives: 2015 Brz Blue Series
Have HKS dual resonated front pipe. Installed Perrin 2.5" over pipe. After installed Perrin over pipe, get periodic vibration sound; BUT only occurs when traction control is off. Did not occur when traction control was off before installed OP
Have loosened and re tightened bolts OP, FP and tightened header bolts.
Suggestions where else I might look or what may be causing? Or what the correlation to traction control being off might be?
Donbrz is offline   Reply With Quote
Old 07-11-2015, 05:55 AM   #11
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
Motiv Concepts overpipe.
JimmyMac is offline   Reply With Quote
Old 07-11-2015, 08:43 AM   #12
_gt86_user
Inactive
Drives: .
Motiv OP no issues
_gt86_user is offline   Reply With Quote
Old 07-11-2015, 08:47 AM   #13
nunonuna
nunonuna's Avatar
You may check this area too as shown in the pictures.
If the gap of indicated area is less than 1/4" when its cool, that is most likely where the noise comes from because metal expands after heat applied.
1. You can adjust the gap by realign OP since invidia flange holes are oval.
2. You can also adjust by front pipe hanger after tighen all exhaust together. I had to do this because PERRIN OP bolt holes are not oval.
3. Do both
nunonuna is offline   Reply With Quote
Old 07-11-2015, 08:00 PM   #14
JG
JG's Avatar
3. Do both
Thats exactly where the poor clearance is. I tried moving everything up. I also tried moving the front pipe hanger as much as i can as well. Is that your set up? that doesn't look like a lot of clearance as well.
Overpipe with sway bar clearance? swift996 Engine, Exhaust, Transmission 40 07-05-2020 06:27 PM
Who's baby is this? Poor poor soul sftateofmind Scion FR-S / Toyota 86 GT86 General Forum 14 04-12-2015 08:48 PM
Your Poor man LFA s here!!! Whitigir Scion FR-S / Toyota 86 GT86 General Forum 54 12-10-2013 11:47 AM
overpipe clearance jamesm Engine, Exhaust, Transmission 12 11-16-2013 01:42 PM
Motiv Concepts Overpipe + HFC, Overpipe + Test Pipe Specials! MotivConcepts Engine, Exhaust, Bolt-Ons 96 07-19-2013 02:03 AM
