Drives: Whiteout FRS
Poor Overpipe Clearance
Current'y i'm running Openflash Header, Invidia Over pipe, Invidia Front pipe, Invidia straight pipe, Invidia N1 tips. My Over pipe seems to have horrible clearance as it is knocking against the metal beneath it.
My question is, does anyone have a good overpipe they would recommend that has good clearance? Also maybe the front pipe doesn't curve up enough? ![]() TY in advance
#2 |
Drives: 2013 Ultramarine FR-S
When I had a Perrin OP, I never had an issue.
#3 |
#4 |
Hisnamewasrobertpaulson
Drives: 2017 Golf R
i also have no issues with my perrin, but i also know plenty of people running the invidia op without any issues. maybe you just need to loosen everything up and re-set and re-tighten in a better place where it won't hit the sub-frame.
This is your life and it's ending one minute at a time.
#5 |
I swapped to a 3 inch OP and front pipe.
I don't remember the clearance amount but it never hit anything. Sent from my iPhone using Tapatalk |
#6 |
I've tried that. I can't tell you the amount of time i was under there and tried moving everything. I ended up wrapping the overpipe so it didn't have that nasty metal on metal sound. I'll look into Perrin then.
#7 |
Drives: 2017 Golf R
if the perrin give you the same problem i'd look into the header as the culprit.
#8 |
Turning is for Nerds
Drives: 35 characters is not enough
I've had no issues with my Motive op paired with either Stock, Nameless, or Tomei headers.
#9 |
#10 | |
Drives: 2015 Brz Blue Series
Have loosened and re tightened bolts OP, FP and tightened header bolts. Suggestions where else I might look or what may be causing? Or what the correlation to traction control being off might be? |
#11 |
Drives: 2013 FR-S, 2016 Miata Club
Motiv Concepts overpipe.
#12 |
Inactive
Drives: .
Motiv OP no issues
#13 |
You may check this area too as shown in the pictures.
If the gap of indicated area is less than 1/4" when its cool, that is most likely where the noise comes from because metal expands after heat applied. 1. You can adjust the gap by realign OP since invidia flange holes are oval. 2. You can also adjust by front pipe hanger after tighen all exhaust together. I had to do this because PERRIN OP bolt holes are not oval. 3. Do both
#14 | |
| Overpipe with sway bar clearance? | swift996 | Engine, Exhaust, Transmission | 40 | 07-05-2020 06:27 PM |
| Who's baby is this? Poor poor soul | sftateofmind | Scion FR-S / Toyota 86 GT86 General Forum | 14 | 04-12-2015 08:48 PM |
| Your Poor man LFA s here!!! | Whitigir | Scion FR-S / Toyota 86 GT86 General Forum | 54 | 12-10-2013 11:47 AM |
| overpipe clearance | jamesm | Engine, Exhaust, Transmission | 12 | 11-16-2013 01:42 PM |
| Motiv Concepts Overpipe + HFC, Overpipe + Test Pipe Specials! | MotivConcepts | Engine, Exhaust, Bolt-Ons | 96 | 07-19-2013 02:03 AM |
